Home > General & Technical (L663) > Link Rods |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2757 |
Can you contact the previous owner? They might still have the original parts.
16th Feb 2023 6:52pm |
Defenderattacker Member Since: 16 Feb 2023 Location: Dorset Posts: 12 |
Already asked. As an alternative does anyone know how long the 2” lift rods are? Then I can work out what the originals were. Thanks.
16th Feb 2023 6:56pm |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 137 |
The Allmakes Terrafirma adjustable lift rods apparently go from standard height to a 2" lift. These are listed for a D3&4, but if the L663 rods are different, the seller will be able to help. (I not so familiar with them as I have never used rods due to the IIDTool having this capability electronically Actually, come to think of it, you could leave the present rods in place and adjust the suspension back down with an IIDTool... )
Click image to enlarge RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
17th Feb 2023 12:04pm |
Yes they are different. Anyone?
18th Feb 2023 3:51pm |
Was hoping to make and fit some replacements over the weekend.
18th Feb 2023 3:52pm |
Anyone?
20th Feb 2023 5:59pm |
MattF Member Since: 28 Oct 2022 Location: Norwalk CT Posts: 32 |
If it would help I have a set of 1" lift rods from Lucky8 I can measure
22nd Feb 2023 12:20am |
Yes please
22nd Feb 2023 8:14am |
1 inch lift links
Long link = 5.5 inches Short link = 3.5 inches Click image to enlarge Click image to enlarge |
23rd Feb 2023 6:48pm |
Thanks very much
23rd Feb 2023 8:02pm |
Centre of each hole in mm would be better, look like they’re actually a bit over your measurements. If it’s anything like a discovery 3 1mm rod length equates to 5mm difference in car height Exact measurements would be good.
23rd Feb 2023 8:05pm |
That's the camera angle - they are not over. I'll get mm measurements for you
23rd Feb 2023 8:48pm |
Hope these help -
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
23rd Feb 2023 9:03pm |
Perfect thank you
23rd Feb 2023 10:17pm |
