![]() | Home > Tdi > dim-dip |
are you sorted bp ? 2.4 90 XS
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5849 ![]() ![]() |
I thought you just had to pull the relay out and connect two terminals?
This shows the terminals http://forums.lr4x4.com/index.php?showtopic=71364 Andy |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6161 ![]() ![]() ![]() |
So that the air flow keeps the resistor cool... it's a huge great aluminium clad wire wound, dropping the 13 or so volts down to about 6v to dim the lights, so gets quite warm/hot. not really safe (read: cool enough) to be behind the dash.
^^^ You're correct. just make up a link to short the 2 main cables together. Then it totally bypasses the system. |
Jamie, when we meet on the plains, maybe you could show me
No probs.
I'll get some pics of the bulkhead on the project90, so you can see the relay in question. I meant to post the party number a while back, as there is a proper "relay" (which is just an empty box with the link inside it) to bypass the dim-dip. |
cheers Jamie. so to be clear, I found the pink relay behind the clocks on the dash-dials. The other link/url suggests a wire link between a couple of the terminals (red/blue wires), the relay has about 7 or 8 connectors on it .. I did not try and open it... nor could I see any red/blue wires.
cheers steve |
Yes, that's right.
See picture below, my 90 bulkhead before I put the dash trim in place, you can see the pink "relay" on the RH side, with the blue/red wires going into it. ![]() Click image to enlarge If you pull said relay out, you should have 7 terminals on the relay base. you need pins 8 & 2, both blue with red trace. This is the main feed in (pin 8, from the off/side/main column switch, via ignition fed relay) then out to the headlights via fuses 22 & 23. All the other 5 pins of that relay relate to the dim-dip stuff. So, short the 2 pins out, and you'll bypass it all. But use decent sized connectors to slide into the socket, or get the correct "bypass" unit (part number to come later when i go out and get it! probably tomorrow now) or get an old relay that fits, remove the lid and guts and solder in a nice sized piece of cable across the 2 terminals) |
cheers Jamie, I'll take a look tonight.
took the ICE defender out yesterday to visit the dealership because the 300's headlights stopped working altogether. standard switch costs £50, copy part £9.99
pulled the dash apart and found the pink D/D relay, did some searching on the web and made the jumper lead - i thought it's worth a try, plugged in and hey-presto ... no dim-dip, side lights, headlights and full beam all working ![]() don't even need the switch... |
