Home > Puma (Tdci) > Central locking issue
aircooled57
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Hi,
I have a problem with my central locking and was hoping for some help to fix the issue.
Most of the time when I turn the ignition on, the car horn will do a double beep.
The car will also unlock, then when I press the drivers door handle to open the door, the entire car will lock then unlock every door except the drivers door.
The immobiliser light on the dash also remains on most of the time.
Any suggestions as to the issue and how to resolve would be appreciated 👍
Post #978852 19th Jan 2023 6:14pm
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Hi!
I had this issue as well - not all doors locking. It turned out to be a chaffed cable inside the affected door that caused the problem. Might be a good spot to check!
Post #981200 4th Feb 2023 9:32am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Tip, check all 4 doors. If they are not chaffed / broken now they will be in a few weeks/months. The thicker wires are just too stiff. Replace them with more flexible wire and problems solved. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #981204 4th Feb 2023 10:16am
bear100
Exactly what the above have said, its mostly likely the wires snapped or almost inside the rubber boot joining the pillar to the door Thumbs Up 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #981230 4th Feb 2023 2:05pm
