![]() | Home > Puma (Tdci) > Central locking issue |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 ![]() ![]() |
Hi!
I had this issue as well - not all doors locking. It turned out to be a chaffed cable inside the affected door that caused the problem. Might be a good spot to check! |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Tip, check all 4 doors. If they are not chaffed / broken now they will be in a few weeks/months. The thicker wires are just too stiff. Replace them with more flexible wire and problems solved. a defender from 1984 pretending to be a puma with a touch of Range Rover
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1979 ![]() ![]() ![]() |
Exactly what the above have said, its mostly likely the wires snapped or almost inside the rubber boot joining the pillar to the door
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
