Home > Puma (Tdci) > Ignition switch replacement |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2031 |
On my 2013 Puma the ignition switch acts as your original switch, so something seams wrong. Check your wiring to the switch, you may have connected it wrong.
See https://www.defender2.net/forum/post561588.html and https://www.defender2.net/forum/post766999.html. For info. |
9th Jan 2023 8:19pm |
driver9 Member Since: 15 Oct 2012 Location: Suffolk Posts: 111 |
Thanks Ian all sorted.
10th Jan 2023 9:17am |
Was it a miss wiring issue ?
10th Jan 2023 12:21pm |
Yes swapped the white/red and white/orange wires over. Knew I should have gone to Specsavers.
10th Jan 2023 12:45pm |
