Home > Puma (Tdci) > Ignition switch replacement
driver9
Fitted a new genuine LR steering lock and ignition switch unit to my 2008 2.4 Defender. Before replacing the unitI I could turn the key wait for the glow plug light to go out before turning the key further to start the engine. Now when I turn the key the engine starts straight away. Is this normal for the later design of ignition switch?
Post #977253 9th Jan 2023 7:27pm
Ianh
On my 2013 Puma the ignition switch acts as your original switch, so something seams wrong. Check your wiring to the switch, you may have connected it wrong.
See https://www.defender2.net/forum/post561588.html and https://www.defender2.net/forum/post766999.html. For info.
Post #977274 9th Jan 2023 8:19pm
driver9
Thanks Ian all sorted.
Post #977330 10th Jan 2023 9:17am
Ianh
Was it a miss wiring issue ?
Post #977348 10th Jan 2023 12:21pm
driver9
Yes swapped the white/red and white/orange wires over. Knew I should have gone to Specsavers.
Post #977351 10th Jan 2023 12:45pm
