Home > My Defender > M57 swap into the Red Baron
Page 5 of 6 <123456>
Mj_pilot
 2011 Defender 110 Other SW Auto Indus Silver
Tensioner as per attached and pulley is 64mm diameter from e90 part number
INA-5320553100 BMW Drive Belt Idler Pulley - INA 11287790448 Purchased from fcp euro.
carrotbay wrote:
Shane / MJ I’m swapping out the power steering pump and air con pump on my E70 engine for 330D parts. Please can you help with the idler under the alternator / next to the tensioner? I bought the part below, but I don’t think it’s right as I think it needs to bolt through the alternator lower mount and the one supplied doesn’t. Do you have the part number you used?
Mj_pilot wrote:
carrotbay wrote:
Shane, this thread has been so useful! I’m currently working on putting a M57N2 from a 2009 X5 E70 in to my 110, and was deliberating over the Blackbird P38 conversion or fitting aircon compressor and steering pump from an E90 - you’ve confirmed that’s the way to go!
(If I’d read this before buying a X5 as a donor then maybe I’d just have looked for a E90 330D instead!)
Do you have any photos of the turbo actuator rotated and the bracket? Does it clear the steering box now?
Post #1025784 24th Feb 2024 6:42am
Mj_pilot
Magic - thankyou.
I’m planning to take off for the transmission cooler but if I ditch that idea I’ll take your advice on board. Cheers.
[quote="shanecl"]
Mj_pilot wrote:
MJ see your pipe for the bottom radiator, the E53 X5 bottom pipe fits straight on and its minus the EGR cooler pipe. can get it on ebay for feck all
Post #1025785 24th Feb 2024 6:46am
Mo Murphy
Progress Shane ! Good to see ! Are you suffering some mission creep with the axles ...
50 Shades of Pennine Grey
Post #1025842 24th Feb 2024 4:34pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Mo, i am the biggest procrastinator and overthinker you will ever come across Laughing
Thanks Mo Very Happy
back on track, fitting fuel system tonight and got to get a lead for the PC so i can fill auto box and we should have some noise coming from it soon Very Happy
Post #1025999 26th Feb 2024 11:44am
shanecl
[quote="Mj_pilot"]Magic - thankyou.
I was thinking of running a water cooler too for the trans but wasn't sure, pulled the trigger on a setrab so see how we go.
The E60 530d cooler i was looking at and easy money on ebay
Post #1026000 26th Feb 2024 11:46am
Mo Murphy
I'll look forward to progress then 👍
Post #1026127 27th Feb 2024 10:44am
tuddy70
Awesome thread Thumbs Up I'm also in the process of doing this conversion, what are you doing handbrake wise? I've noticed one or two do away with the drum in favour of the park on the auto box but not sure about it.
Post #1026244 28th Feb 2024 11:06am
tuddy70
carrotbay wrote:
Mj_pilot wrote:
Carrotbay,
The turbo actuator on my install clears. It’s close but it clears. The plug housing touches the steering box but I may get away with it. Otherwise, just need to trim the housing a bit.
Thanks MJ - really useful
I got my engine in this week and I’m probably a few mm further forward as the actuator plug is very tight against the steering box. I’m going to space it back a little on it’s mounting bolts and that should do the trick.
Good to see the belts, just waiting for some bits to arrive and that should sort that. What are you doing for power steering hoses?
Hi Carrotbay, regarding the power steering hoses I read that off the shelf 200tdi are a direct fit so could be worth a look to save a few quid, Ive noticed people offering a conversion for double the price of these Shocked
Post #1026246 28th Feb 2024 11:09am
shanecl
Sorry Carrotbay, i didnt see the last bit asking about the power steering hoses.
I got some hydraulic pipes made up. I'll take a picture and send you the size and lengths of the hoses. They are pretty short as the pump is right beside the box. I will do it this evening or Thursday Very Happy
Post #1026247 28th Feb 2024 11:20am
shanecl
So this is what £200 pounds of air con fittings look like Big Cry
I was struggling with the air con as they use a different type of fittings and trying to get my head around it. Finally have it cracked and plan is to machine a new block with threaded fittings that connects to the evaporator and then buy an Eaton hose kit and make the hoses myself, Heading to machine shop Thursday to see how much it'll be to machine the block and maybe make a couple
Post #1026250 28th Feb 2024 11:34am
jst
i just bought a kit for ac hoses to replace pipes on my 2,4 with ac, m57n2 being fitted Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1026265 28th Feb 2024 3:25pm
shanecl
Where did you get it jst
Shane
Post #1026345 29th Feb 2024 10:13am
Linds Hanson
I think Marcus does the evaporator adaptor
Post #1026351 29th Feb 2024 10:52am
shanecl
Thanks Linds,
I got the large compressor fitting and the condenser fitting off him.
Shane
Post #1026358 29th Feb 2024 12:03pm
jst
Shane
Marcus Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1026366 29th Feb 2024 2:00pm
