Home > Puma (Tdci) > County side window trim advice.
silvermilnec
Anyone any advice or link to online video.
I have a 90 van that before I purchased had panoramic side windows fitted and rear front facing seats installed.
I’ve tried to make it a nicer place to be by sound deadening and insulation but I’d now like to finish it off with the 4 piece trim panels pictured.
Does anyone know if any of the holes for installing are there on all back types or will I need to start drilling? What fixings are needed?
Hope this makes sense! Any help appreciated 👍
Yes I keep telling myself I should have bought a XS county🙈 but too deep now and I love it!!
Post #973724 6th Dec 2022 9:17pm
DSC-off
Hi, depending on the type of seats and seatbelts fitted, you may be better off with older style (td5 type) side trims.
If the seats are genuine puma type and the seatbelts are in the factory puma location at the top rear corner, there are features in the panels to line up with them.
If they're not fitted the same as factory seats, then you may end up having to modify the trim panels to suit.
I'd suggest having a good look at a standard station wagon and compare it to how yours is.
Sorry, I can't answer any questions about fitting.
Post #973731 6th Dec 2022 9:39pm
silvermilnec
Thanks for the reply, the seats are e more trim but the seatbelts are in the factory location.
I know I will need to fabricate a bracket to get the seat to stick out a bit when folded away as they fit too close to the window. I’m just hoping the rear as the required holes to pick up on the fur trim plugs and screw holes for the grab handles oh and hope it doesn’t all rattle 😂
Post #973735 6th Dec 2022 9:47pm
