Home > Puma (Tdci) > County side window trim advice. |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1440 |
Hi, depending on the type of seats and seatbelts fitted, you may be better off with older style (td5 type) side trims.
If the seats are genuine puma type and the seatbelts are in the factory puma location at the top rear corner, there are features in the panels to line up with them. If they're not fitted the same as factory seats, then you may end up having to modify the trim panels to suit. I'd suggest having a good look at a standard station wagon and compare it to how yours is. Sorry, I can't answer any questions about fitting. |
6th Dec 2022 9:39pm |
silvermilnec Member Since: 23 Nov 2021 Location: West Yorkshire Posts: 27 |
Thanks for the reply, the seats are e more trim but the seatbelts are in the factory location.
I know I will need to fabricate a bracket to get the seat to stick out a bit when folded away as they fit too close to the window. I’m just hoping the rear as the required holes to pick up on the fur trim plugs and screw holes for the grab handles oh and hope it doesn’t all rattle 😂 |
6th Dec 2022 9:47pm |
