![]() | Home > General & Technical (L663) > Tyre pressures |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20591 ![]() ![]() |
Mines a Puma 90 but I run 34F 36R.
I seem to get even tread wear with those pressures, I find 32F you tend to get a little more shoulder wear each side of the tread and not equal over entire tread. Play Stupid Games, Win Stupid Prizes. Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
Sepp Member Since: 05 Oct 2020 Location: Bavaria Posts: 114 ![]() ![]() |
I am running the ND on 48F and 48R (3.3 bar) at all road conditions (book value for fully loaded vehicle).
Yields much more stability at corners, at breaking and at high speed (>100mph in Germany). No kind of 'rock hard' ride, air suspension does the job well even with high tyre pressure. |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 161 ![]() ![]() |
Have a look at @allnewdefenderoffroad and @afterthelandroverexperience on Insta and YT. They've posted videos showing their use of lower tyre pressures when off-road.
Airing down does cause the TPMS to "beep" at you and there's no way to disable it AFAIK, you just have to ignore it. For normal use, LR's guide says to inflate to the pressures recommended in the Tyre Pressure Information screen in the IP display. https://www.ownerinfo.landrover.com/docume...c/G2401273 Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2925 ![]() ![]() |
I was referring to my old 2005 Defender when l said the ride was rock hard with higher tyre pressures, the new one is obviously a lot better but l was just wondering what tyre pressures people were running. |
