Home > General & Technical (L663) > Tyre pressures
lightning
Tyre pressures
The book says 34psi front, 37psi rear for most conditions
Has anyone tried lower pressures? Over on the old Defender forum almost nobody runs the pressures recommended which are 48psi rear and 32psi front, because it makes the ride rock hard.
Most people recommend 36/30 unless loaded up
Post #973143 1st Dec 2022 11:40pm
Mines a Puma 90 but I run 34F 36R.
I seem to get even tread wear with those pressures, I find 32F you tend to get a little more shoulder wear each side of the tread and not equal over entire tread. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #973144 1st Dec 2022 11:53pm
Sepp
Germany
I am running the ND on 48F and 48R (3.3 bar) at all road conditions (book value for fully loaded vehicle).
Yields much more stability at corners, at breaking and at high speed (>100mph in Germany).
No kind of 'rock hard' ride, air suspension does the job well even with high tyre pressure.
Post #973216 2nd Dec 2022 4:59pm
WizzardPrang
Have a look at @allnewdefenderoffroad and @afterthelandroverexperience on Insta and YT. They've posted videos showing their use of lower tyre pressures when off-road.
Airing down does cause the TPMS to "beep" at you and there's no way to disable it AFAIK, you just have to ignore it.
For normal use, LR's guide says to inflate to the pressures recommended in the Tyre Pressure Information screen in the IP display.
https://www.ownerinfo.landrover.com/docume...c/G2401273 Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #973280 3rd Dec 2022 12:41am
lightning
I was referring to my old 2005 Defender when l said the ride was rock hard with higher tyre pressures, the new one is obviously a lot better but l was just wondering what tyre pressures people were running.
Post #973283 3rd Dec 2022 1:42am
