Home > Technical > Defender 130 TDCI Puma non starter
Page 2 of 2 <12
audi1boy
United Kingdom 2008 Defender 130 Puma 2.4 HCPU Barolo Black
Hi Blackwolf thanks for the input.
If I am getting readings from all the sensors i.e crank, rail pressure, MAF etc would those reading run through the ECU and then to the OBD? Suggesting as I have all those readings that the ECU is OK?
Just thinking outside the box...how can i test the pump pressure without the ECU interfering and possibly causing the low pressure?
Is it possible to apply 12 volts directly to the VCM to open it giving maximum flow of fuel to the pump and thus meaning a low pressure reading must be the pump? I know there is a risk that it could over pressurise and blow the Relief Valve?
Post #975130 19th Dec 2022 1:52pm
I'm afraid I don't know how the ECM actually modulates the VCV, so I don't know if what you propose is viable. As far as I recall there are only two wires connected to the VCV so my guess would be that its a PWM signal. It would, I suppose, be easy enough to apply a 12V signal to the VCV and crank the engine.
Do you have any way to see if the signal from the ECM is reaching the VCV? An open circuit in the harness might prevent the engine from starting.
An ECM fault would not necessarily affect all aspects of the ECM's operation so that fact that it is reporting valid sensor data does not necessarily rule it out.
Have you replaced the fuel rail pressure relief valve (you don't list it in your recent post)? This is a non-resetting valve which must me replaced if it "pops", is there any chance it has done so?
Post #975145 19th Dec 2022 3:16pm
audi1boy
Morning,
Sorry forgot to say, yes I replaced the Relief Valve, copper seal and torqued to the correct amount.
The issue I have is that the engine has done extremely high miles at 280,000 miles. The last owner who had it from new was insistent that it was on the original engine.
I am loathed to go about changing the diesel pump, timing chain etc on an engine that really has gone well to get that far.
It was running extremely well before it conked out however.
I will look at getting a decent low mileage replacement engine rather than dealv into that one.
The issue will be one finding one that I believe to have the claimed miles on it. They all seem to say 40,50k etc.
No doubt i will then find out its the ECM/ECU.
Thanks for all your help.
Post #975207 20th Dec 2022 8:35am
Scorpioinbarnsley
United Kingdom 2007 Defender 110 Puma 2.4 USW Indus Silver
Did you ever resolve this. Seems to be same issue I am having
Post #1053386 29th Nov 2024 9:19pm
Scorpioinbarnsley
Post #1053387 29th Nov 2024 9:19pm
Page 2 of 2 <12
