Home > Td5 > Fuel Pump or Relay? |
Sounds like the fuel pump to me. I had the same thing after a fuel stop. Also so suddenly. No been able to rev the engine and no power. I could get up to 70 km/hr barely.
My gus would be the pump but you can easily check the relay. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
17th Nov 2022 3:57pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 900 |
I’ve ordered some relays, so I’ll have spares if nothing else. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
17th Nov 2022 4:01pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
A relay wouldn't be progressive like that, it's a switch. On or off. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
17th Nov 2022 4:10pm |
Tank out then. Charlie
17th Nov 2022 4:12pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17462 |
^ Not easy on a 90. I'm afraid.
17th Nov 2022 5:57pm |
I’ve heard . . . I have a drawer fixed in the back so I can’t just hack a hole into the floor.
I do have the YRM tank cradle fitted, so should be less of a battle. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
17th Nov 2022 6:06pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
I have had almost identical issues.. You literally could be describing the problems I had/have. Fuel pump not running, issues at those revs etc.
I first had my fuel pump replaced on recommendation from the garage, but my suspicion was this was a red herring. It was as the problem persisted. I found that by pressing the fuel pump relay after it had failed that I could make the pump squeak as the connection was temporarily restored. I had the relays all rewired ensuring the ends of the wires were trimmed to expose fresh metal All was good for a couple of months then the truck broke down when my wife was driving it alone. Got it recovered. Wouldn't fire at all and engine management warning light was on. Fixed that by removing/refitting the 30A fuse from under the seat box. As soon as I did that the warning light went out and it started immediately. So I am now thinking I have an intermittent ECU problem which is fixed when removing the fuse which forces it to restart. There's stuff online about faulty ECUs causing the power dropouts around 2-2500 rpm. This is as far I I have got. Two problems, one solved by sorting the relay and another still unsolved and waiting to strike another day! Will get the ECU tested next... |
17th Nov 2022 6:41pm |
Interesting.
I have a suspicion the pump has been slowly dying, as I noticed a while back that it was quieter than usual when first priming. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
17th Nov 2022 7:47pm |
458GT Member Since: 22 Jun 2022 Location: Warwickshire Posts: 83 |
Interested to hear how you both get on .... never fun
Just out of interest why is it difficult to change the fuel pump on a 90? When the time comes I can't bring myself to get the floor cut so will just let the (initially willing) garage crack on with it... |
17th Nov 2022 10:19pm |
Click image to enlarge Click image to enlarge I think that answers that then. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
30th Nov 2022 3:10pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 626 |
You can remove the plastic cover of relay and watch, if it is switching. And you can also manually press the moving contact of relay, to switch it on. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
30th Nov 2022 4:14pm |
I gave it a push into the connector block and it started working again, so I’ve replaced it for a new one.
All working again. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
30th Nov 2022 4:24pm |
At the very least it is worth opening up the cover just to see where the singeing originated. I had to replace all the yellow relays in Miffy. The contacts within the relays had badly eroded over time. Caused the overheating and blackening, plus some irritating running issues.
30th Nov 2022 4:27pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3374 |
I had similar issues to yours. Replace the injector harness with a sealed unit, cleaned the ECU plugs up and jobs a good un. £50 and half an hour of your time.
HAve you checked the red and the black plugs going into the ECU under the seat for any traces of oil? |
30th Nov 2022 4:40pm |
