![]() | Home > Td5 > Fuel Pump or Relay? |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5274 ![]() ![]() |
I am starting to suspect my in tank pump is failing, After todays test. Would yours not pick up after 40 mph? mine will not go over 40 mph, its starts to struggle, and wants me to change down, and starts to idle a little rough. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
Mine was fine to 2,500rpm and then spluttered. Now that the relay has been replaced, the pump makes a strong noise and performance is fine. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
where is the fuel relay located? something i can check tomorrow.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 546 ![]() ![]() |
Under the drivers seat, nearest the transmission at the rear are two yellow relays, one of them is the fuel pump relay. On mine its the rearmost one,
If you count 1 to 3, 1 being towards the rear - that’s the fuel pump relay. Charlie
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 368 ![]() ![]() ![]() |
You need to be careful because with old trucks it is quite possible that the relays have been moved about and are not in the correct position.
Had that problem on my truck and I read similar on here too.... TD5 hardtop to Puma inspired Poptop - my build thread 2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
Best to ID the Td5 fuel pump relay from the wire colours:
White/Purple Purple/White Brown/Orange Blue/Purple In descending wire size order. ![]() ![]() |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1233 ![]() ![]() ![]() |
Fuel pump relay must the weakest point in any car. I have had Volvo's, Mercedes, BMW, Porche, etc all suffer from burned out relays, typically at a parking lot. They obviously carry a lot of load, but you would think they could make them solid state! At least the Td5 it is just an ordinary relay so cheap to replace even preventative, say every few years.
However looking at your socket, you might want to gently remove the terminals one by one (battery disconnected of course) and clean them up and tighten them up a little. Then the new relay will seat properly and you don't start building up heat and burning up the new relay with a poor connection. You should also watch a few of these Vice Grip Garage Video's, its amazing what can be fixed on the side of the road. It ain't dead till you tried everything. I have dismantled carburetors on the side of the road. The only time I called in the tow truck what when the clutch (hard pipe) failed on my S3, I could have driven it home without a clutch, but it was not worth damaging the gearbox (and the recovery was free..) |
