Home > Td5 > Fuel Pump or Relay?
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Fuel Pump or Relay?
Looking for some ideas relating to a fault on my Td5 90.
Last Friday I drove up to the Peaks for the weekend. I ragged around a couple of passes before stopping in Holmfirth for lunch. At this point all was fine.
After grabbing lunch I made my way back up to the top of Holme Moss to enjoy said lunch. However, on the way up the 90 wouldn’t rev above 2,500rpm. It was down on power and not particularly happy. Got to the top and plugged in the Nanocom. No faults, MAF fine, coolant temp. fine, injectors fine.
After scoffing lunch and doing some online research I turned on the ignition and noticed something - silence from the fuel pump. In neutral it wasn’t revving as fast as it should and wouldn’t really go beyond 3,000 - 3,500rpm.
I left the 90 parked until Sunday morning for the trip home. Start-up was rough and smokey, but settled after a few short seconds.
I managed to drive at 45-60mph for 60 miles, which got me a way down the M1. After 55-58 miles I noticed I couldn’t maintain power on the flat any more, the engine was sounding spluttery, and I was holding up HGVs. I tried rev matching on the down-change, only to find it wouldn’t rev. When speed fell to 30mph, the alarm bells were ringing - I dived into Trowell services. Here the 90 was rough and barely idling. I attempted to reverse into a parking space and it stalled. After this it refused to start. The AA came and recovered me back to base fairly swiftly, which was a pleasant surprise.
Now, I think I’ve diagnosed this to a fuel pump or relay issue. The glow plug and MIL lights both illuminate correctly, but the pump is totally silent. The relay has never been changed yet the original pump was replaced with a VDO unit as a precautionary measure about 18 months back. I should hope the pump wouldn’t die so soon. Also, there are no fuel leaks.
What do people think? Pump? Relay? Earth?
Could the relay cause this kind of progressive failure? Overall, it happened within the space of 70-80 miles, so perhaps it’s not that progressive . . .
I won’t be with the vehicle until Monday week, so I can’t physically check anything beforehand.
 Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #971440 17th Nov 2022 2:51pm
roel
Sounds like the fuel pump to me. I had the same thing after a fuel stop. Also so suddenly. No been able to rev the engine and no power. I could get up to 70 km/hr barely.
My gus would be the pump but you can easily check the relay. Roel
2003 90 Td5 (2009-now)
Post #971448 17th Nov 2022 3:57pm
BaronDefenders
I’ve ordered some relays, so I’ll have spares if nothing else. Thumbs Up Charlie
2002 Td5 90 (SOLD)
Post #971449 17th Nov 2022 4:01pm
Martin
Site Admin
A relay wouldn't be progressive like that, it's a switch. On or off.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #971450 17th Nov 2022 4:10pm
BaronDefenders
Tank out then. Sad Charlie
2002 Td5 90 (SOLD)
Post #971451 17th Nov 2022 4:12pm
^ Not easy on a 90. I'm afraid. Sad
Post #971470 17th Nov 2022 5:57pm
BaronDefenders
I’ve heard . . . I have a drawer fixed in the back so I can’t just hack a hole into the floor.
I do have the YRM tank cradle fitted, so should be less of a battle. Charlie
2002 Td5 90 (SOLD)
Post #971476 17th Nov 2022 6:06pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
I have had almost identical issues.. You literally could be describing the problems I had/have. Fuel pump not running, issues at those revs etc.
I first had my fuel pump replaced on recommendation from the garage, but my suspicion was this was a red herring. It was as the problem persisted.
I found that by pressing the fuel pump relay after it had failed that I could make the pump squeak as the connection was temporarily restored. I had the relays all rewired ensuring the ends of the wires were trimmed to expose fresh metal
All was good for a couple of months then the truck broke down when my wife was driving it alone. Got it recovered. Wouldn't fire at all and engine management warning light was on. Fixed that by removing/refitting the 30A fuse from under the seat box. As soon as I did that the warning light went out and it started immediately.
So I am now thinking I have an intermittent ECU problem which is fixed when removing the fuse which forces it to restart. There's stuff online about faulty ECUs causing the power dropouts around 2-2500 rpm.
This is as far I I have got. Two problems, one solved by sorting the relay and another still unsolved and waiting to strike another day! Will get the ECU tested next...
Post #971483 17th Nov 2022 6:41pm
BaronDefenders
Interesting.
I have a suspicion the pump has been slowly dying, as I noticed a while back that it was quieter than usual when first priming. Charlie
2002 Td5 90 (SOLD)
Post #971498 17th Nov 2022 7:47pm
458GT
Interested to hear how you both get on .... never fun
Just out of interest why is it difficult to change the fuel pump on a 90? When the time comes I can't bring myself to get the floor cut so will just let the (initially willing) garage crack on with it...
Post #971517 17th Nov 2022 10:19pm
BaronDefenders
I think that answers that then. Charlie
2002 Td5 90 (SOLD)
Post #972957 30th Nov 2022 3:10pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
You can remove the plastic cover of relay and watch, if it is switching. And you can also manually press the moving contact of relay, to switch it on. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #972965 30th Nov 2022 4:14pm
BaronDefenders
I gave it a push into the connector block and it started working again, so I’ve replaced it for a new one.
All working again. Thumbs Up Charlie
2002 Td5 90 (SOLD)
Post #972966 30th Nov 2022 4:24pm
geobloke
At the very least it is worth opening up the cover just to see where the singeing originated. I had to replace all the yellow relays in Miffy. The contacts within the relays had badly eroded over time. Caused the overheating and blackening, plus some irritating running issues.
Post #972967 30th Nov 2022 4:27pm
camelman
I had similar issues to yours. Replace the injector harness with a sealed unit, cleaned the ECU plugs up and jobs a good un. £50 and half an hour of your time.
HAve you checked the red and the black plugs going into the ECU under the seat for any traces of oil?
Post #972968 30th Nov 2022 4:40pm
