![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
tooth_dr Member Since: 26 May 2021 Location: Northern Ireland Posts: 237 ![]() ![]() |
Has anyone got theirs recalibrated to D300 yet using GAP? I’ve about every other thing activated and thinking that surely the remap must be possible too. But then again if it was then why has nobody sussed it out yet and posted online.
rabalam Member Since: 30 Jan 2025 Location: Washington Posts: 3 ![]() ![]() ![]() |
@northeye
Once you enable this feature for a soft touch, how do you activate it or configure your PIVI screen to show the softkeys? Thanks |
northeye Member Since: 18 Sep 2022 Location: Tokyo Posts: 19 ![]() ![]() |
Reboot the Pivi system with press and hold the off/volume button for 20 seconds.
DC-Defender Member Since: 23 May 2024 Location: USA Posts: 10 ![]() ![]() |
Anyone notice any additional options in the CCF file since installing the latest Pivi Pro 4.3.0 update?
@northeye
I have an interesting issue. I'm not sure this is why it's not working. The below is the module you posted in the original post. * MultiCAN-898 Rear Htd Screen Soft Button from "Not Fitted" to "Soft Button Fitted" The ACTUAL module on the GAPTool is: * MultiCAN-898 Read Htd Screen Soft Button from "Not Fitted" to "Soft Button Fitted" Could this be the issue? I cannot find the original "rear" module. I've up dated my Gaptool to the latest firmware. |
"read Htd Screen" is correct.
But it means "rear heated screen", I believe. |
@northeye,
Okay thanks, it must be my LR633 then, I've done the hard reset on the Pivi and still no soft buttons. I'll keep searching though. ~r |
