Home > Puma (Tdci) > Injectors replacement
Rivarama
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zermatt Silver
2 of my injectors need replacing on my 2009 2.4 TDCI 110 as the computer readings showed negative values when tested. Given the injectors have never been replaced over the past 13years, am I better off replacing the whole lot at once, or would you just replace the 2 that seem to be failing?
Also - can you please confirm the replacement p/n is DCRI107060 (Denso). It seems to be very difficult to pin what the right p/n is and none of the online resellers seem to be able to confirm it is the one I need. They all need me to unless give them the p/n of the ones I have on the car (which obviously I can’t remove until I get them replaced by my local indy)
Thanks in advance
Post #963468 31st Aug 2022 7:32am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
Replacing all at once would be my recommendation as good practice if you can afford it. If two have failed chance is the other two won’t be far behind.
Twice yearly I use a cataclean fuel flush in quarter tank of fuel just as a routine, I also add millers diesel additive every time I fuel up. I may be a little old school but believe this is a good routine for preventive maintenance.
Anyone else have a view? Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #963473 31st Aug 2022 8:03am
BrickBox
I do find that running a diesel fuel cleaner helps keep them running smooth.
I just use the Redex £2 shot bottle every once in a while, especially through winter I find it helps. 2008 2.4 110 Utility Station Wagon XS.
Post #963476 31st Aug 2022 8:37am
Rivarama
Thanks for the response.
What abt the p/n is that Denso p/n what I need?
Thanks
Post #963557 31st Aug 2022 5:35pm
This link any help?
https://www.pfjones.co.uk/diesel-fuel-pump...ctors.html TheThunder Rolls🇬🇧🇺🇸
Post #963580 31st Aug 2022 7:46pm
Rivarama
Well this is exactly why I am asking.
I have asked PF Jones what model I need for my car and they cannot tell me until I remove an injector from my engine and give them the reference.
Why would there be 3 models of injectors at 3 different prices for the same car (2.4 TDCI 2006 onwards)
Obviously I like the price of DCRI107060 (and it is new, not refurbed) better but how do I know whether that’s the right model?
Post #963587 31st Aug 2022 8:26pm
HardCharger
Have you consulted with LR Workshop? I find their parts reference pages extremely helpful and spot on
Post #963607 1st Sep 2022 3:22am
Leamreject
And just to add another dimension to this, your local Ford dealer could probably supply you a set at better value than a LR set Whistle Ride like you stole it!!
2011 2.4 Puma 90 HT
Post #963609 1st Sep 2022 3:29am
Rivarama
Yup - I cannot find a definitive answer, which is why I turned to the forum.
The LR p/n seems to be LR006803 for the 2.4 TDCI but I am not 100% -
So given the ticket is £800+ I would like to know whether that’s really the right LR p/n first and that the Denso p/n is the right equivalent… can’t seem to find a definitive answer and PF Jones won’t confirm anything until I remove an injector.
I usually trust forum specialists more than those guys Smile
Post #963624 1st Sep 2022 6:28am
MK
Hi
Ask ford for p/n 6C1Q-9K546-BC.
MK Puma 110" SW
Post #963634 1st Sep 2022 8:58am
hank
Post #963649 1st Sep 2022 10:30am
Rivarama
Quick Q for the group.
I just bought the injectors and the VCV too. I have just called a local Indy and he quoted me 8h to replace the injectors and the VCV and go through the learning process.
It feels excessive - especially given that the current injectors have already been removed 6months ago to get cleaned and replaced the copper washers - so there shouldn’t be any surprises or stuck bolts anywhere. Given the hourly rate in the south east it might be close to £1k for labor alone.
Am I out of touch with prices?
Post #965038 14th Sep 2022 7:33pm
MK
Skilled mechanic should do it in less than 3 hours max Puma 110" SW
Post #965044 14th Sep 2022 8:04pm
BrickBox
Get a Haynes manual and do it yourself Whistle Cool
Spend the saved labour money on some extras instead. 2008 2.4 110 Utility Station Wagon XS.
Post #965050 14th Sep 2022 8:36pm
bear100
What tool is best to buy that will code the injectors? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #965059 14th Sep 2022 9:03pm
