![]() | Home > Puma (Tdci) > Injectors replacement |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Replacing all at once would be my recommendation as good practice if you can afford it. If two have failed chance is the other two won’t be far behind.
Twice yearly I use a cataclean fuel flush in quarter tank of fuel just as a routine, I also add millers diesel additive every time I fuel up. I may be a little old school but believe this is a good routine for preventive maintenance. Anyone else have a view? Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 886 ![]() ![]() ![]() |
I do find that running a diesel fuel cleaner helps keep them running smooth.
I just use the Redex £2 shot bottle every once in a while, especially through winter I find it helps. 2008 2.4 110 Utility Station Wagon XS. |
Rivarama Member Since: 28 Aug 2021 Location: London Posts: 155 ![]() ![]() ![]() |
Thanks for the response.
What abt the p/n is that Denso p/n what I need? Thanks |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20636 ![]() ![]() |
This link any help?
https://www.pfjones.co.uk/diesel-fuel-pump...ctors.html TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Well this is exactly why I am asking.
I have asked PF Jones what model I need for my car and they cannot tell me until I remove an injector from my engine and give them the reference. Why would there be 3 models of injectors at 3 different prices for the same car (2.4 TDCI 2006 onwards) Obviously I like the price of DCRI107060 (and it is new, not refurbed) better but how do I know whether that’s the right model? |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 751 ![]() ![]() ![]() |
Have you consulted with LR Workshop? I find their parts reference pages extremely helpful and spot on
And just to add another dimension to this, your local Ford dealer could probably supply you a set at better value than a LR set
![]() If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
Yup - I cannot find a definitive answer, which is why I turned to the forum.
The LR p/n seems to be LR006803 for the 2.4 TDCI but I am not 100% - So given the ticket is £800+ I would like to know whether that’s really the right LR p/n first and that the Denso p/n is the right equivalent… can’t seem to find a definitive answer and PF Jones won’t confirm anything until I remove an injector. I usually trust forum specialists more than those guys ![]() |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2455 ![]() ![]() ![]() |
Hi
Ask ford for p/n 6C1Q-9K546-BC. MK Puma 110" SW ............................................................. Earth first. Other planets later |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2317 ![]() ![]() ![]() |
Quick Q for the group.
I just bought the injectors and the VCV too. I have just called a local Indy and he quoted me 8h to replace the injectors and the VCV and go through the learning process. It feels excessive - especially given that the current injectors have already been removed 6months ago to get cleaned and replaced the copper washers - so there shouldn’t be any surprises or stuck bolts anywhere. Given the hourly rate in the south east it might be close to £1k for labor alone. Am I out of touch with prices? |
Skilled mechanic should do it in less than 3 hours max Puma 110" SW
Get a Haynes manual and do it yourself
![]() ![]() Spend the saved labour money on some extras instead. 2008 2.4 110 Utility Station Wagon XS. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1958 ![]() ![]() ![]() |
What tool is best to buy that will code the injectors? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
