Home > In Car Electronics > Ignition Live |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
Hi, to power the sub normally the manufacturer will specify a fused permanent live and a switched live from the head unit, normally output on the blue wire. The blue wire tells the sub when the head unit is powered up so the sub powers up too. Seeing as you’ve got a 90 the sub will be near the battery so take the live straight from there (and earth back to the battery too) with a suitably rated inline fuse.
For your reversing camera the simplest way of taking a 12v feed for this is to tap into the reversing light feed, assuming you only want the camera to power up when in reverse. |
30th Aug 2022 10:03pm |
Sepulchre Member Since: 28 Jun 2022 Location: Angus Posts: 38 |
Thanks Penfold, that's a big help. I should point out my 90 doesn't have a sub currently and I'm yet to remove the middle seat to see what's there, maybe nothing...?
30th Aug 2022 10:09pm |
If there’s a middle seat there’s unlikely to be anything else there. Powered subs take up very little space and a good addition, simple to wire in too - good for a self confessed beginner.
30th Aug 2022 10:12pm |
Thanks again Penfold, lots to learn!
30th Aug 2022 10:32pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2900 |
Think about a battery ignition sense module from Mobile Centre and a blue sea secondary fuse box. Gives you lots of extra permanent and ignition feeds for accessories down the line Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
31st Aug 2022 6:40am |
