Home > In Car Electronics > Ignition Live
Sepulchre
United Kingdom 2006 Defender 90 2.5 TD HT Cairns Blue
Ignition Live
Hi all,
I'm looking at dropping a powered sub into my td5 90 as part of a new audio system to upgrade the current after market head unit and original speakers, I'll also be fitting a reversing camera whilst I've got the headlining out.
Most of it I can figure out, but time to make an admission... I'm new to car electrics so can someone point me in the right direction of what I need to power this and how to go about it? I figure an ignition live but that's where my knowledge stops Embarassed
Thanks muchly!
Post #963445 30th Aug 2022 10:46pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Hi, to power the sub normally the manufacturer will specify a fused permanent live and a switched live from the head unit, normally output on the blue wire. The blue wire tells the sub when the head unit is powered up so the sub powers up too. Seeing as you’ve got a 90 the sub will be near the battery so take the live straight from there (and earth back to the battery too) with a suitably rated inline fuse.
For your reversing camera the simplest way of taking a 12v feed for this is to tap into the reversing light feed, assuming you only want the camera to power up when in reverse.
Post #963447 30th Aug 2022 11:03pm
Sepulchre
Thanks Penfold, that's a big help. I should point out my 90 doesn't have a sub currently and I'm yet to remove the middle seat to see what's there, maybe nothing...?
Post #963449 30th Aug 2022 11:09pm
Penfold_6290
If there’s a middle seat there’s unlikely to be anything else there. Powered subs take up very little space and a good addition, simple to wire in too - good for a self confessed beginner.
Post #963450 30th Aug 2022 11:12pm
Sepulchre
Thanks again Penfold, lots to learn!
Post #963452 30th Aug 2022 11:32pm
mcma1
Think about a battery ignition sense module from Mobile Centre and a blue sea secondary fuse box. Gives you lots of extra permanent and ignition feeds for accessories down the line Thumbs Up Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #963463 31st Aug 2022 7:40am
