Home > Td5 > Dash Ventilator - 2000 TD5
BADMOJO
United States 2000 Defender 110 Td5 CSW Oslo Blue
Please help
have been scouring internet for days to no avail
My 2000 Td5 had original dash when I got it. I installed the 2004 TD5 version then it caught fire and burned in my garage.
Now, I am rebuilding it and have sourced a 2004 TD5 dash but can not figure out how to attach the ventilator plate.
my original plate has tabs that screw into the bulkhead but the newer version has no tabs.
are there supposed to be some brackets?
If so, anyone have a part number for these brackets?
does it just free float? so confused!!
Post #958181 13th Jul 2022 5:07pm
Dinnu
Never taken a 2002-2006 dash out.. however the top dash will triangulate with the panel and should be enough?
On LRWorkshop, there are some pictures of the panel, and they also seem to be tab free (the RHD model is clearer to see).
https://www.lrworkshop.com/diagrams/land-r...r_52657#15 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958198 13th Jul 2022 7:13pm
BADMOJO
thank you... yeah, that's what I'm thinking, must just form support when combined with the top dash piece.. gonna give it a go now
Post #958199 13th Jul 2022 7:22pm
BADMOJO
went with the triangulation method.. seems to work but these holes lining up with old brackets makes me think there should be more to it. like some brackets between bulkhead and plate
Post #958559 16th Jul 2022 8:29pm
rallysteve
The bulkhead brackets on my 2002 are different to the earlier ones (pre 2002) in that they have an extended section with a captive thread which receives screws straight through the ventilator panel.
As you are probably aware, the original older one would have screwed into the sides of those three brackets (screw holes visible in your pics still) and the ventilator panel would have had three tabs on the back for fixing
I havent got any great pictures but hopefully you can make something out from these:
Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #958649 17th Jul 2022 6:36pm
BADMOJO
Perfect!! Thank you!
I’m assuming that those are welded to the bulkhead..?
Guessing there is no way for me to fabricate them based on pictures
Seems like someone would be making these but highly doubt it
The hint is on for a solution
Post #958665 17th Jul 2022 8:44pm
