Home > Td5 > Dash Ventilator - 2000 TD5 |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Never taken a 2002-2006 dash out.. however the top dash will triangulate with the panel and should be enough?
On LRWorkshop, there are some pictures of the panel, and they also seem to be tab free (the RHD model is clearer to see). https://www.lrworkshop.com/diagrams/land-r...r_52657#15 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
13th Jul 2022 7:13pm |
BADMOJO Member Since: 12 Jul 2022 Location: OREGON Posts: 4 |
thank you... yeah, that's what I'm thinking, must just form support when combined with the top dash piece.. gonna give it a go now
13th Jul 2022 7:22pm |
went with the triangulation method.. seems to work but these holes lining up with old brackets makes me think there should be more to it. like some brackets between bulkhead and plate
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
16th Jul 2022 8:29pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2228 |
The bulkhead brackets on my 2002 are different to the earlier ones (pre 2002) in that they have an extended section with a captive thread which receives screws straight through the ventilator panel.
As you are probably aware, the original older one would have screwed into the sides of those three brackets (screw holes visible in your pics still) and the ventilator panel would have had three tabs on the back for fixing I havent got any great pictures but hopefully you can make something out from these: Click image to enlarge Click image to enlarge Click image to enlarge Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
17th Jul 2022 6:36pm |
Perfect!! Thank you!
I’m assuming that those are welded to the bulkhead..? Guessing there is no way for me to fabricate them based on pictures Seems like someone would be making these but highly doubt it The hint is on for a solution |
17th Jul 2022 8:44pm |
