Home > Technical > Park Brake Light Stuck on, Switch location? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5789 |
The switch is attached to the lever / handle mechanism inside the cab, normally inside the rubber boot. It just has one wire going to it which comes through from behind so under the vehicle by the seat box.
Pull the rubber boot off inside and all will be clear |
7th Jul 2022 3:44am |
Best pic I can find at this time of day. But should explain.
C0091 is the switch connector |
7th Jul 2022 3:49am |
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 108 |
So odd, I actually do not appear to have a switch? Here is a photo of the boot pulled up
Thank you for the help Click image to enlarge |
7th Jul 2022 4:03am |
Doesn’t look like you do. A better pic
7th Jul 2022 4:10am |
Maybe I have a bulb in the wrong location… maybe the light is actually for something else. Have to take the dash out and maybe look at the wires / colors. I k is there is a schematic out in the wild web somewhere
7th Jul 2022 4:14am |
Doesn’t even look like you have the mounting holes in your lever assembly.
7th Jul 2022 4:17am |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
My 1988 90 does not use that Park Brake indicator. The binnacle was also used on Leyland trucks, not just LandRovers, so there are unused warning lights. Could be something done by a previous owner?
As I have commented on your other thread, if the oil level in the brake master is low, it will actually illuminate the warning sign under the battery warning, not the Park Brake. Edit: Or was it the one on the right of the battery warning... was so long ago 😭 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
7th Jul 2022 4:35am |
Ah ok thank you how do I check the master level? Is it located under the hood? Thank you so much
7th Jul 2022 4:58am |
Yes, located under the hood, right above where the brake pedal is located. You might see a sticker / sign to only use Dot3 from a sealed container. You may also use Dot4 as Dot3 is probably hard to find (and is lower specs anyway). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
7th Jul 2022 5:26am |
Thank you for the help, I will take a look tomorrow. I also attached a photo of the bulb harness. Looks like the wire colors are white with a green stripe and black
7th Jul 2022 6:01am |
That is a strange wire combination. Land Rover used to use white for supply on the bulb and then a colored (striped or solid) color to the switch that grounds the circuit.
Any idea where the wires go to? Do they go into the main harness? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Jul 2022 12:12pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1942 |
i had a recent leak on one of the metal brake pipes going to the rear, had the same as you with the flickering light at first but then stayed lit, after checking the handbrake switch the reservoir was the next port of call. 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
10th Jul 2022 2:58pm |
Thanks for all the help. I did some searching for wiring schematics, and it’s interesting as they all seem to vary? I decided to go ahead an order a service manual. Figured be good to have if I am going to try and fix these things. According to one schematic I found… green with white strip is signal indicator?
I’ll have to dig In the dash and try to follow the wire Click image to enlarge |
10th Jul 2022 3:50pm |
I think the low fluid level in the reservoir illuminates the BRAKE (!) warning light, not the PARK BRAKE. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Jul 2022 4:14pm |
