Home > Puma (Tdci) > Wheel Carrier Recommendations
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
After some advise, I’m looking for a wheel carrier for the rear of my 110.
The rear door has the Optimill security hinges fitted and I know the ORE one requires them to be shaved slightly.
Does anyone have any recommendations?
Thanks
Post #957494 6th Jul 2022 6:55pm
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
Have you asked the ORE whether they could do you a spacer plate?
I think the version that fits older defenders comes with a spacer to allow for the crossmember tabs.
If you only need a couple of mm, maybe that would work? 2011 CSW XS 90
Post #957506 6th Jul 2022 8:51pm
MattyEssex
Looking on ORE’s website they have a picture of the Optimill hinge trimmed.
It does state the below on the website along with a picture (that I am unable to upload) that shows where someone has shaved the bottom of the hinge off.
Does it work with Optimil Hinges? – Our wheel carrier was designed to work with all well-known hinges on the market at that time. Since then Optimill has released a security hinge that sits much prouder on the body so our wheel carrier won’t fit. Sadly we cannot modify the top bracket of our carrier or the bearing housing for a number of structural/design reasons. Some customers asked about a packer plate but then that pushes the wheel away from the door as well as create a number of other geometry issues not to mention looking terrible sitting that far away from the door! There is, however a few workarounds: -Fitted security hinges by others that are not so proud on the body (most others on the market), Fitted the Optimill hinges bar the bottom one and left the bottom as a factory hinge or Shaved the bottom corner of the hinge off with a file or grinder where it contacts the wheel carrier bracket to allow clearance (photo in the product gallery)
Post #957511 6th Jul 2022 9:28pm
chrismack85
United Kingdom 1999 Defender 90 Td5 PU Belize Green
Re: Wheel Carrier Recommendations
Chris here from ORE,
Someone messaged me about this post as I don’t use this forum very often.
Drop us an email from contact field on website
Basically I’m got the guys cutting spacers… the overhang of the tub over the xmember is LR
Factory tolerance +/- 8mm I’m reliably told. This means some fit with no issue and some fit with trimming.
Plan is to have a spacers made 1 to 4mm and you can select from spare parts section of the website. It will Take a couple of weeks as we’re flat out with back orders and Just moved to a bigger premises which has been somewhat painful in terms of disruption.
Email us for anything further as I don’t use this platform often
Thanks
Chris
Post #957538 7th Jul 2022 6:22am
MattyEssex
Thanks Chris and will do.
I’ll also be making use of the discount code to use at ORE available for the members here D2N.
Post #957551 7th Jul 2022 8:20am
I've been very pleased with the (whisper it) Britpart one that I have fitted. It does require a couple of holes drilling, which I know that some people are squeamish about. Anyway, there's more detail about its fitting here:
https://www.defender2.net/forum/post833606.html#833606
 Darren
Post #957554 7th Jul 2022 8:29am
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Yes seconder for the britpart one. Have had on for nearly 7 years without a problem. I did change some of the bolts for stainless. No idea if it is compatible with aftermarket hinges though.
Post #957572 7th Jul 2022 10:48am
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
I've been using the nakatanenga spare wheel carrier for about four years now. It was expensive but I think it's worth it. The weight is completely transferred to the rear crossmember and if I recall correctly, it did not require any drilling. It was the only one I found at the time that transferred all the load from the door to the crossmember while looking stock or close to stock.
https://www.nakatanenga.de/en/optional-equ...nder-sw/ht
Post #958687 18th Jul 2022 7:13am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Had a Nakatenga carrier since new (actually the first one lasted 18 months and saved the back of the car from a lot of damage after being hit by a truck) cant beat the quality & service from Barbara & Brendan at 4x4 Overlander
 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #958704 18th Jul 2022 10:33am
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
+1 for ORE. Fitted mine with the TMD hinges, no problems.
It does require two people when fitting.
Post #958727 18th Jul 2022 2:25pm
bear100
Had an ORE one fitted to mine for a couple of years now with no issues all, I also have the Optimill hinges fitted, mine didn’t require cutting and I’m surprised to hear that some have? Sounds odd?
Anyway the ORE unit is still as new with no issues, I’m very fussy and very happy with it. 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #958774 18th Jul 2022 8:27pm
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
I have the new Optimal Security Hinges which foul on the ORE wheel carrier. I used a file and dremel to take the hinge corner off to allow the carrier. Simples...
ORE will not alter their kit or supply anything to accommodate the Optimal hinges. Chris at ORE said he purchased and reached out to all available at the time on the market and Optimal didnt mention a redesign. R&D was extensive from ORE.
Post #958809 19th Jul 2022 8:54am
Sulisuli
Nick bw.
Chris from Ore posted this on this thread Thumbs Up
Thanks
Chris 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #958819 19th Jul 2022 10:59am
Landymatt
I have a Nakatanenga and it's superb... really well made, is lasting well, just looks and feels bullet proof.
The one downside (apart from the price) is that I believe it's not compatible with Bowler rear steps without some major (to me) alterations,
Matt
Post #958842 19th Jul 2022 1:13pm
It's also incompatible with tailgates Big Cry and (I think) military bumperettes Big Cry
Post #958847 19th Jul 2022 1:34pm
