![]() | Home > Puma (Tdci) > Wheel Carrier Recommendations |
silvermilnec Member Since: 23 Nov 2021 Location: West Yorkshire Posts: 27 ![]() ![]() |
ive had 3 different types ORE now fitted and won't be changed, expensive especially if you buy other makes and not happy and change like me!!
Possibly cat amongst the pigeons here, it is not as new or sexy as the ORE or Naka carriers, but... Safari Equip on ol'Miffy...
I have had the same wheel carrier for twenty years or so now and it works a treat. Back then I went for the version with the hi-lift jack mount and it was ace... but taller tyres put a stop to that and the fact the jack hides the fog light is a no-no for me. The carrier though is strong and easily carries the weight of a 285 on Boost wheel plus my weight when loading the roof rack ![]() ![]() ![]() Safari Equip - https://www.safari-equip.co.uk/shop/land-r...post-2002/ |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Which ones did you try before the ore? |
Timcat Member Since: 20 Jul 2016 Location: Rugby at the moment Posts: 1025 ![]() ![]() ![]() |
ORE all the way ( be prepared to cut the bottom Optimill hinge if you have the later version) had a Mantec for 5 years but there’s a big difference between the two. Yes ORE is a lot more cost wise but the design & quality of components is chalk & cheese.
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 290 ![]() ![]() ![]() |
And another ORE user - Top quality product, epic customer service and help if needed, and manufactuered in the UK, Whats not to like ?
![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17724 ![]() ![]() ![]() |
Has anyone on here fitted the ORE tailgate version yet? I'd be interested in a review.
