Home > Technical > Snowchains
Page 2 of 2 <12
I have some MilZ product AG, from Switzerland - you may find them cheaper / better in the Alps or in European Snowy regions where they are more readily available - and get quality, no point having them if they break the first time you use them - (so avoid Aldi specials Rolling with laughter )
These were about £180 for a pair to fit standard 235's
as for the snow socks - you might as well put them on your feet and wear them, they don't last long Mr. Green
Post #91968 29th Sep 2011 6:08pm
noworries4x4
Somebody mentioned towing in the snow, sorry bad idea been there tryed that, over run brake trailers nightmare on hills and the main problem is them dragging you backwards and once your slipping its already gone wrong so hang on for the ride. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #92043 29th Sep 2011 9:32pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Which chains are they and what's your price BigMike? Or did they sell already?
Post #92353 3rd Oct 2011 6:19am
AndrewS
I have a set of four chains, (one set goes on one tyre)
Last year I tried, just on the front, just on the back and on all 4.
The results were as follows:-
On the front = grip for drive OK, if heavy braking going down hill on a camber the back end would slide out a bit. Steering would wobble due to the fact that chains were on the tyres.
On the back = grip for drive OK, if heavy braking going down hill on a camber the front end would slide out a bit.
On front and back = Awesome.
Please note that I was driving at about 20mph on a quiet back lane and when safe to do so I slammed the brakes on to see what would happen. The vehicle used as a 130 without ABS. Under normal 'driving in snow' circumstances you would not slam the brake on. When braking genitally in the snow the vehicle stooped in a straight line.
If I only had 2 sets I think I would put them on the back, simply because the steering wheel would not wobble. 130's have feeling's as well you know Smile
Post #92364 3rd Oct 2011 8:28am
JSG
AndrewS wrote:
... When braking genitally in the snow the vehicle stooped in a straight line.
'kin 'ell - must take a lot a balls to do it that way Shocked
Laughing John
2011 Tdci 110 CSW XS
Post #92376 3rd Oct 2011 9:49am
Lorryman100
Shocked I'm impressed by the size of your Balls in your dedication in testing this theory Bow down Bow down And to think Fred Flinstone used his feet to stop Laughing
Post #92377 3rd Oct 2011 9:53am
AndrewS
Embarassed Dam predicktiv text Embarassed 130's have feeling's as well you know Smile
Post #92521 3rd Oct 2011 9:29pm
Green Machine
Rolling with laughter 2005 Td5 | 90 Station Wagon | Tonga Green
Post #92528 3rd Oct 2011 10:06pm
BigMike
Pewag Brenta-C. Willy had them Thumbs Up
Post #92530 3rd Oct 2011 11:00pm
leeds
If you want a set of snow chains, how abot a set of these?
Brendan
Post #94296 14th Oct 2011 9:04pm
noworries4x4
Brendan
Bondage for tractors Embarassed :oops:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  If everything is under control you are not going fast enough.
No Worries 4X4
Post #94302 14th Oct 2011 9:46pm
DanoDEF
my snow chains
Post #94376 15th Oct 2011 4:20pm
MuddyMarky
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
BigMike wrote:
Zagato wrote:
I thought these wheel sock jobbies were the latest thing - maybe not then Confused
fine on a fiesta to get you home, but not on a vehicle with any kind of torque or weight.
We use the socks on the fire engines at work - but then, they only weigh 13 tons, and probably don't have much torque either Wink
They actually work great, but have to be careful when the road clears, as mentioned above, holes start to appear. Mark
2011 110 XS DC
Stornoway Grey
Post #94399 15th Oct 2011 6:48pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
DanoDEF wrote:
my snow chains
That's what mine look like Thumbs Up Not going to smash those up in a hurry.
Post #94407 15th Oct 2011 7:13pm
Page 2 of 2 <12
