![]() | Home > Td5 > Anti roll bar installation |
Eppilihp Member Since: 10 Aug 2019 Location: Emmental Posts: 61 ![]() ![]() |
I hope you don't mind if I jump in with my set of problems...
I trashed my original rear ARB 15 years ago somewhere in Gabun. Now I thought it might be sensible to install a new ARB kit. So I went and bought a standard one, plus I organised a spacer because of my 2" lift. So far so good, but now when I try to install it, the bar seems to be too narrow? The bar links are not lined up correctly IMHO. Anyone knows what's going on here? How can I "fix" this? ![]() Click image to enlarge ![]() Click image to enlarge And yes the screws are not tightened on the pix, ignore that! BTW this is my old One Ten my88. Is the mount on the chassis maybe a bit to wide for this piece of kit? ![]() |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1236 ![]() ![]() ![]() |
Looks like the ARB is bent. The bars towards the axle should be parallel to each other.
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681 ![]() ![]() ![]() |
Only thing I can think of like above its bent or it maybe the wrong type for the Salisbury axle you have? Are rover axle brackets different?
Not sure it's bent, it's just not wide enough. Are there different sizes? Could someone with a salisbury axle measure the dimensions of the ARB? |
