Home > My Defender > 20 year wait over
Page 2 of 6 <123456>
Dave12345
United Kingdom 1989 Defender 90 300 Tdi PU Keswick Green
Thanks both.
Not quite ready to start ripping up the floor but I’ll have to try one of the many good suggestions soon as I bought a roof sides and door today - off to collect them from
a chap who converted his to canvas in a couple of weeks. Looking forward to getting it back to its original SW form.
Also gave it its first oil change tonight. Only a small job but we bonded fighting over the filter and it feels much more like “my” Land Rover now. Should have bought a bigger tub really though.
Post #954991 8th Jun 2022 10:30pm
Dave12345
Phase one of swapping from truck cab back to its original SW form started today.
No better time to go topless than in a heatwave. I’m gonna take some convincing to put a roof back on! Took it round the block and it’s so much fun like this.
Post #961378 11th Aug 2022 10:29pm
Dave12345
Just for my own records and far less interesting, there is now zero surface rust under the car. There was only really any on the back axle but I went around and dabbed hydrate 80 on anything that was even thinking about beginning to rust, couple of hidden bits on the tub straps for example, and did a full coat on the axle/diff below:
Little before and after:
Now I’m happy that there’s nothing left to creep I’m going to fully lanoguard it. With the LG I appreciate it’s not necessary to go around with Bilt Hamber first but I feel more comfortable with a two pronged approach.
I’m determined to keep it as rust free as I can (within reason of course).
Post #961380 11th Aug 2022 10:55pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
Looks good, enjoy the experience, from a fellow Northwestener.
Post #961402 12th Aug 2022 9:50am
Dinnu
Time for some new rear bump stops Whistle
The underside looks as good as the bodywork Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #961404 12th Aug 2022 10:49am
excossack
Did you spray on the rust converter or apply with a brush? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #961405 12th Aug 2022 11:00am
Ianh
Hydrate-80 should be applied sparingly by brush, 2 coats , 30 mins between first and second coat, and second coat brushed 90 degrees to the first. whenever applied to pitted surfaces you stipple with end of brush to ensure it gets into the pitted area.
I’ve used this on several vehicles and it does a great lasting job that does not show brush marks as It has a very low viscosity. For chassis or anything under the body I then topcoat with corroless chassis paint in one which can be spray ( available in spray cans) or brush applied.
Post #961422 12th Aug 2022 2:06pm
excossack
Cheers. 1999 Defender TD5 110
Regards
John M0VAZ
Post #961423 12th Aug 2022 2:11pm
Dave12345
Thanks all! Yes applied by brush as above. Great stuff, very easy to use (if you don’t knock over half the bottle and then roll into the puddle).
What have you seen regarding bump stops? Is that the bottom of the shocks?
I’m tempted by fox shocks so don’t give me any excuses.
Today I took off the mangled mud console that came fitted to it. Good news and bad…
The good is that there is some wiring there, which I’m hoping is for a radio. (Although there’s no aerial, nor is the single remaining speaker connected to anything)
I also refitted the wiring to the cig lighter to power a stick-in USB. Proud of working that one out.
The bad news is that someone has absolutely butchered the lower dash 😭
I had actually wanted to totally remove the console, back to original and go for an invisible audio installation but that’s out the window now unless I replace the bottom dash - I’m assuming this could be tricky.
Option B is to hide it with a new non-broken mud console, embrace it, and fit a double din. Hmm.
Post #961477 12th Aug 2022 9:10pm
The first photo in your third post shows the rear offside bump stop to be missing altogether. It should be attached to the plate on the bottom of the chassis rail where the axle would hit if the suspension bottoms out.
Post #961479 12th Aug 2022 9:44pm
Dave12345
Edit for getting mixed up.
Would that be this bit here?
Thanks for letting me know.
Post #961486 12th Aug 2022 10:36pm
Aha, you edited that whilst I was marking up your photo! That's the thing.
The thing you highlighted initially is the mount for the rear anti-roll bar, if fitted.
The bump stop mount is highlighted in the picture below.
Post #961487 12th Aug 2022 10:47pm
Dave12345
Perfect thank you - I’ll add that to the list!
Post #961493 12th Aug 2022 11:49pm
Dinnu
Post #961497 13th Aug 2022 5:36am
Dave12345
Hardtop successfully on - back to its original SW form.
I’m normally found in the wild but treated ourselves to a proper campsite this weekend with some mates. Nothing fell off on the twisty welsh roads which I’ll take as a positive.
The roof needs some paint but I’m in no rush.
Post #962499 22nd Aug 2022 12:10pm
