Home > In Car Electronics > Wiper Park Switch? |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5733 |
Park switch would be my bet.
2nd May 2022 10:58am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17463 |
Actually with those symptoms the relay would be first bet rather than the switch (and it is a lot easier to get to)! Do you have access to a spare relay you can try? It would very quickly check if it was the relay at fault.
2nd May 2022 12:51pm |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 320 |
I was in two minds @blackwolf. I would expect 12v on the NLG wire at the relay with the wipers in the park position but I'm not getting one. I'll pop round the motor factors in the morning, I suspect they're more likely to have the timer relay than they are the park switch. It would save taking the whole dash to pieces.
2nd May 2022 12:56pm |
Well...that was interesting. A bit of swapnostics during my lunch hour - New timer relay fitted, no change. New wiper park switch fitted, no change!
Upon deeper inspection the yellow/green wire had come off the back of the column switch, can't believe nobody suggested this as a potential issue!! lol The brass fitting was a bit loose, gave it a bit of a squeeze and popped it back on, wipers now working fine. |
4th May 2022 5:49pm |
Well done sorting out the problem. At least you now have a handy spare relay.
4th May 2022 6:27pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4720 |
Filed for future reference Hope I remember it 1982 88" 2.25 diesel
13th May 2022 1:28pm |
