Home > In Car Electronics > Wiper Park Switch?
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Wiper Park Switch?
Hi folks, I have checked the search function on the forum and am pretty sure I am convinced but just to check my homework -
2002 Td5
Wipers don't park
No intermittent wipe
No wipe when wash function activated
Wipers work fine on normal and fast speed (apart from parking)
All issues point to failed park switch on motor not delay ECU behind dash???
Thanks, MM
Post #951309 2nd May 2022 10:07am
landy andy
Park switch would be my bet. Thumbs Up
Post #951316 2nd May 2022 10:58am
Actually with those symptoms the relay would be first bet rather than the switch (and it is a lot easier to get to)! Do you have access to a spare relay you can try? It would very quickly check if it was the relay at fault.
Post #951325 2nd May 2022 12:51pm
Penfold_6290
I was in two minds @blackwolf. I would expect 12v on the NLG wire at the relay with the wipers in the park position but I'm not getting one. I'll pop round the motor factors in the morning, I suspect they're more likely to have the timer relay than they are the park switch. It would save taking the whole dash to pieces.
Post #951326 2nd May 2022 12:56pm
Penfold_6290
Well...that was interesting. A bit of swapnostics during my lunch hour - New timer relay fitted, no change. New wiper park switch fitted, no change!
Upon deeper inspection the yellow/green wire had come off the back of the column switch, can't believe nobody suggested this as a potential issue!! lol Rolling with laughter
The brass fitting was a bit loose, gave it a bit of a squeeze and popped it back on, wipers now working fine.
Post #951581 4th May 2022 5:49pm
Well done sorting out the problem. Thumbs Up At least you now have a handy spare relay.
Post #951589 4th May 2022 6:27pm
spudfan
Ireland
Filed for future reference Thumbs Up Hope I remember it Whistle 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #952480 13th May 2022 1:28pm
