Home > Td5 > Remappping for Economy.
Page 1 of 3 123>
Bobble
Tell me about remaps and economy........Just something I'm considering.
Post #90694 22nd Sep 2011 9:37pm
K9F
I'll tell you that if you punch "remaps" into the search facility it comes up with 50 threads..... Thumbs Up
Upto 20% more economy if you can resist the urge to toe it! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #90699 22nd Sep 2011 9:42pm
Bobble
Yep, had a quick search, just wondered what the latest thinking is.....
Post #90702 22nd Sep 2011 9:45pm
K9F
Had a remap for a couple of years now! 20% fuel economy increase claimed and can get it too if I drive carefully. But 'on balance' economy is the same but driveability and torque increases alone are worth the spend!
If you're doing it purely for economy reasons only forget it! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #90705 22nd Sep 2011 9:54pm
Yorkshire90
Re: Remappping for Economy.
Do it, the 90 Im selling has a Stage 2 remap. It has all the go and with none of the MPG drops unless driven with some serious gusto. Last MPG calculations were 29-30-31mpg *not in that order!*
With the TD5 I'd definitely go for the Stage 2 with the Intercooler and EGR removed to keep the temperatures down... I can highly recommend 2 tuners out there...
Post #90707 22nd Sep 2011 10:00pm
Yorkshire90
Also, when you enquire about havin your TD5 remapped, state your requirements.
Many, if not all tuners have several fuelling maps to cater your needs, ranging from a mild economy map that might not require the larger cooling properties of the performance intercooler all the way up to race spec "smokey" maps...
Post #90716 22nd Sep 2011 10:19pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I had my TD5 sorted by Gary at Alive, when he asked me what i wanted i asked for smoother power and better economy. So far ive not been able to go on a good run as im busy at work but so far running around local little roads and a snails pace its gone from about 26-27mpg to about 30-31 mpg which isnt a million miles from a 20% increase. My best mpg before was 32.5mpg from one tank so im hoping to see the better side of 35 mpg now, will have to wait and see!
Post #90925 23rd Sep 2011 6:13pm
Bobble
Hmmm, thanks for all the feedback. Will sleep on it.
Post #90927 23rd Sep 2011 6:17pm
Yorkshire90
Then wake up, stretch and go to Bell Auto Services/IRB Developments for a Stage 2 Thumbs Up
Post #91407 26th Sep 2011 6:09pm
Yorkshire90
Yawning optional Very Happy
Post #91408 26th Sep 2011 6:09pm
BigMike
So, remap is what? 500 quid?
If you drive for economy after that - lets me optimistic and say you get a 20% increase in economy.
tank size for a 90 - 13.2 imperial gallons so at todays prices around £84 (140 a litre or £6.36 per gallon). If you averaged 28 mpg before, you get 33.6 post remap driving sensibly.
before: 369 miles per tank (har har)
after 443 miles per tank (yeah right)
a benefit of 74 miles. or 2.2 gallons per tank.
2.2 gallons is £14
cost of remap is 500 quid divided by the benefit £14 = 35 tanks of fuel to get that benefit.
so you would need to drive 35 x 443 = 15,500 miles to see the benefit.
This assume that you always drive for economy for those 15,500 miles, get that MPG (33.6), never tow or go uphill, and of course that fuel prices remain the same.
It's a no from me.
Post #91440 26th Sep 2011 8:35pm
landy andy
Had a remap (not by Alive) done, and loved it.
Then went and met Gary (Alive Tunning) at Billing. He remapped my Td5 again, and WOW, what difference, much better power delivery, less smoke and lower exhaust temps (better for engine).
But more importantly for you, much better on fuel, even when using the power.
Even my wife said "why don't they make them like this"
Andy
Post #91444 26th Sep 2011 8:43pm
WarPig
Morning glory optional Very Happy
Post #91450 26th Sep 2011 8:58pm
Bobble
2.2 gallons is £14
It's a no from me.
That was my thought process. Neutral
Post #91471 26th Sep 2011 10:17pm
landy andy
I can assume that you have not driven one that has been remapped, if you drive one you would soon change your mind.
Biggest shock for me was how much quieter it became, let alone smoother, and easier drive.
If your local, give me a shout and have a go of mine.
Andy
Post #91475 26th Sep 2011 11:05pm
Page 1 of 3 123>
