Home > Wheels & Tyres > opinions ??
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
opinions ??
hi guys im looking to put a different set of tyres on my truck but am unsure what size as most of you know i run a ome lift 2inch ish and nrmally run simex 35inch tyres
i want to run a trye that wont look silly on the truck but also isnt 35 so possible a soemthing below a 33
i was thinking 285 75 16s
anyone got an idea
kind regard steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #90643 22nd Sep 2011 8:04pm
GoodYear Duratrac Thumbs Up
Post #90645 22nd Sep 2011 8:08pm
jst
my truck cab has an OME 2" lift, i run 255.85R16 BFG MTS on it, they fill the arches sufficiently and are narrow enough to not sacrifice lock. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #90650 22nd Sep 2011 8:17pm
big steve
i was hoping ud post ken what size tyres were you running
im more interested in sizes as mines tops out at 80 due to tyre size
i think iv got my heart set on bfg all terrains Whistle
cheers steve 2015 2.2 tdci hardtop xs
Post #90651 22nd Sep 2011 8:18pm
noworries4x4
With your vnt turbo and re-programming with tyres that size i would expect you to be up on the wrong side of 100 (i would'nt want to try) but rolling diameter and loads of BHP and torque you should be flying. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #90692 22nd Sep 2011 10:29pm
Me post on a wheel tyre thread never Mr. Green
Steve Im on 285/75/16 on Mach 5's just about to swap to Mods from the winter months so I can PC the Mach 5's Thumbs Up
Post #90827 23rd Sep 2011 1:25pm
K9F
Ken,
You changing colour of the Mach 5s? I know mine aren't that old but this will be the third Winter season I've had mine on and the coating is standing up very well! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #90835 23rd Sep 2011 1:52pm
Only caus I can no other reason
Post #90843 23rd Sep 2011 2:30pm
big steve
Dnt forget you loose slot aswell trying to pull such a big tyre round ??
Steve 2015 2.2 tdci hardtop xs
Post #90913 23rd Sep 2011 6:54pm
ickle
bfg a/t
I'm on 285/75 16 on BFG A/T's on a standard tune 110 puma and can sit on the speed limiter all day, they fill the arches and speedo is spot on.
Keith
Post #90941 23rd Sep 2011 8:23pm
big steve
I think that's what in guns go for how wide do they measure ?
Regards steve 2015 2.2 tdci hardtop xs
Post #90948 23rd Sep 2011 8:47pm
ickle
I'll measure and try to photo tomorrow, but on 0mm offset 8" silversport alloys the tread is just covered by the standard arches.
Keith
Post #90951 23rd Sep 2011 8:51pm
big steve
Well I'm guns be putting on 8.5 inch rims altho unsure on what offset us I hope it's 0
Post #90953 23rd Sep 2011 8:54pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
runing 255/85/16's BFG's on my DC with 5" lift, thats got the 300tdi VNT on that...they don't look lost in the arches.. Putting Dreams on Drives at JLR Solihull..
Post #90954 23rd Sep 2011 8:57pm
Lorryman100
If you go 285's you will need an offset of 30mm whether that's with spacers or inbuilt into the wheel. I have a few sets of wheels and tyres, 305/70x16 mickey T's on pro comp alloys I bought from Discocuzzy, 265/75x16 BFG MT 's on mods and GG TR's 235/85x16 on boosts. I did have a set of BFG AT's 235/85x16 on mods but gave them to my mate as I was not impressed with them in the wet. The best tyre I have is the 305 Mickey Thomson Baja ATZ's as the really do stick to the road. They are a good all round tyre in mud and snow and are brilliant, yes brilliant in soft sand whilst towing the boat for launch/recovery. As there is so much rubber in contact with the tarmac you can fly around bends with ease and I've not noticed any problems with the engine turning the wheel with the remap, I bottled it at 97mph on the M74 Whistle When the GG TR's wear down I will replace them with a set of Mickey T ATZ's in 265 on the boosts. I don't have a lift on the Puma but there is no clearance issues with the 305's but I haven't a lot of extra weight up front. I do have a set of OME springs for the 110 which were bought in anticipation of fitting larger wheels but subsequently were not needed.
The 305 size will probably suit you better Steve as you have a lift and they fill the arches nicely,
When I get back home I have some pics showing the difference between the 235's, 265's and 305's in snow as I was the only person to go up the same road showing the differences between them , so I can post them if it helps?
HTH Brian.
Post #90967 23rd Sep 2011 9:36pm
