Home > Puma (Tdci) > Red light on |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Press unlock before starting.
Immobiliser kicks in after a certain time. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
17th Apr 2022 7:01pm |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 368 |
My spare remote has always behaved like this, never found a reason why. My day to day remote starts the car first time, as it should do. My spare remote will only start the car after I have re-locked and unlocked using the remote. Seven years it's been like that, so have just learnt to live with it. Fob battery change made no difference. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
17th Apr 2022 8:59pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1999 |
Should be that remote fob battery is too low. once fob battery changed go outside the vehicle with doors closed, I stand close to the drivers door as the alarm module is under the dash above the drivers footwell. click the lock button on the fob four times and it will re sync. Then unlock with fob and make sure its on the same ring as the key and it should start first time. If you have two key fobs only have one fob with you each time you do this as having both fobs in close proximity can cause issues.. so leave one indoors. Do the first fob re sync process and start the vehicle. . Then stop after a minute , take new synced fob in doors bring other one out and repeat process. |
17th Apr 2022 10:57pm |
