![]() | Home > Off Topic > Smart smoke detectors |
Chopperone Member Since: 13 Nov 2016 Location: Derbyshire Posts: 396 ![]() ![]() |
Hi
Anyone got any experience of Smart smoke alarm/detectors? Any to avoid OR what is best? I am thinking the Nest 2nd Gen ones might be best but at just shy of £100 per detector I want to make sure I am buying right. I use OS and also have Amazon Alexas around the house. I have a very good commercial grade WiFi network & 4g. TIA Guy May your life be like toilet paper ; long & useful. |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4216 ![]() ![]() ![]() |
Genuine question, why a smart one? What does it do that a normal one doesn’t? 2007 110 TDCi Station Wagon XS
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 ![]() ![]() ![]() |
Another vote for Nest for reasons above.
Mine might be 1st gen, not sure. Had them for around 4+ years now, have been faultless & not yet had to change a battery (they tell you when they need it). |
Thanks everyone; l will go down the Nest route
Cheers Guy May your life be like toilet paper ; long & useful. |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Before you launch into a big purchase check that there isn’t going to be a law change with respect to domestic smoke and flame detectors coming in the next 2-3 years. Here in Scotland we have been supposed to have had interlinked heat, flame and CO detectors fitted in certain rooms in every house (old or new build) since February. I have purchased wirelessly interlinked Fireangel heat and fire detectors (I have no open fires in the house house so no CO detector is required). I went over and above the rules as a boxed set of detectors was cheaper than buying the 3 that were required in my bungalow by adding a detector in each bedroom and an additional heat detector out in the garage. My only reason for adding the bedroom detectors was that the audible alarm wasn’t that powerful an alarm in the lounge and hall if the bedroom doors were closed. Interlinking means if one sensor is triggered then all the sensors will sound. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
