Home > Maintenance & Modifications > Koni heavy track raid pin to pin
Page 2 of 2 <12
8619simon wrote:
That's an awesome photo of an awesome road and view! Thumbs Up
Post #969873 3rd Nov 2022 8:20pm
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
Thank you. It was a fantastic trail, a bit butt clenching in a couple of spots, but the view was spectacular 😀
Post #969887 3rd Nov 2022 10:00pm
8619simon
hxk494 wrote:
Would love to hear more about the explorer set up you went with as your 110 is almost exactly the same as mine, 300tdi, same tent etc and similar usage by the sound of things and have been planning a bit of a suspension upgrade for some time.
What springs/lift are you running and what shocks (2001 Front & 2009 Rear?) Front ARB or no ARB?
Anything else useful you can share would be much appreciated.
Cheers, Martin
Hi Martin….. Details of the kit are here:
https://gwynlewis4x4.co.uk/product/explorer-suspension-kit-info/
I had a few conversations with Gwyn and described my set and requirements and he suggested the specific springs etc, well worth doing as he is extremely knowledgeable and a lovely chap.
Because of the roof load I have I went with the firmer valving on the rear shocks which controls the lean etc nicely. Springs on the rear are OME2754 and OME2751 on the front. It gives it a bit of body lift but I like the stance and it means I can load up heavy when on a bigger trip. Because of the rear lift I also went with his HD cranked rear trailing arms.
I’m running a standard ARB on the front but no ARB on the rear.
Post #969889 3rd Nov 2022 10:16pm
geobloke
Such a good setup. As and when you decide to add a rear ARB I can highly recommend the X-Eng X-Delfex kit (now Foundry 4x4). It gives a superb amount of control in the corners and has the flexibility to be disconnected when you need the extra droop.
Post #969890 3rd Nov 2022 10:29pm
Page 2 of 2 <12
