![]() | Home > Maintenance & Modifications > Koni heavy track raid pin to pin |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17731 ![]() ![]() ![]() |
That's an awesome photo of an awesome road and view! ![]() |
8619simon Member Since: 05 Nov 2016 Location: North Wales Posts: 257 ![]() ![]() ![]() |
Hi Martin….. Details of the kit are here: https://gwynlewis4x4.co.uk/product/explorer-suspension-kit-info/ I had a few conversations with Gwyn and described my set and requirements and he suggested the specific springs etc, well worth doing as he is extremely knowledgeable and a lovely chap. Because of the roof load I have I went with the firmer valving on the rear shocks which controls the lean etc nicely. Springs on the rear are OME2754 and OME2751 on the front. It gives it a bit of body lift but I like the stance and it means I can load up heavy when on a bigger trip. Because of the rear lift I also went with his HD cranked rear trailing arms. I’m running a standard ARB on the front but no ARB on the rear. |
Such a good setup. As and when you decide to add a rear ARB I can highly recommend the X-Eng X-Delfex kit (now Foundry 4x4). It gives a superb amount of control in the corners and has the flexibility to be disconnected when you need the extra droop.
