Home > Puma (Tdci) > Battery Recommendations
Page 2 of 2 <12
macfrank
The Zee wrote:
(the alarm will sound as the battery is detached)
It wont if you turn the ignition on and off, remove the key and within 15 seconds detach the battery terminals. It's all explained in the owner's manual. (the what I hear people say Wink
Post #943600 23rd Feb 2022 8:30pm
The Zee
United Kingdom 2014 Defender 110 Puma 2.2 USW Indus Silver
Tried the ignition on-off thing - I found 15 seconds was not enough time to get out, run round, grab ratchet, and disconnect safely. Tried a couple of dry runs, just not long enough. Big Cry
Let the alarm howl, it goes quiet after about 60 second and them makes a squeak every 20 seconds! Neutral
Won't have that madness to deal with for at least 5 Years (I hope) Zaid-M
www.DefencePhotos.com
2014 Defender 110 Utility, 2.2 Puma, Indus Silver
Not just transport more like a religion
Post #943603 23rd Feb 2022 8:50pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Just remove the ignition key from the passenger’s side the disconnect the negative lead?
15 seconds as ample time.
Post #943605 23rd Feb 2022 9:00pm
macfrank
Laughing You can loosen the terminal a bit before actually removing them.
Also helps if you have a LHD Whistle
Post #943606 23rd Feb 2022 9:12pm
Page 2 of 2 <12
