Home > Puma (Tdci) > Battery Recommendations |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 289 |
Tried the ignition on-off thing - I found 15 seconds was not enough time to get out, run round, grab ratchet, and disconnect safely. Tried a couple of dry runs, just not long enough.
Let the alarm howl, it goes quiet after about 60 second and them makes a squeak every 20 seconds! Won't have that madness to deal with for at least 5 Years (I hope) Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
23rd Feb 2022 7:50pm |
Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 300 |
Just remove the ignition key from the passenger’s side the disconnect the negative lead?
15 seconds as ample time. |
23rd Feb 2022 8:00pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1082 |
You can loosen the terminal a bit before actually removing them.
Also helps if you have a LHD |
23rd Feb 2022 8:12pm |
