![]() | Home > My Defender > Lizzy |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 586 ![]() ![]() ![]() |
Just taken Lizzy to https://foxlandrover.co.uk for a break fluid change and a/c gas top up.
Really impressed by this little independent. If they're close to you, look them up. |
Fitted the Nugget Stuff air intake. The instructions say to cut the old pipe in to bits to remove. This is what I needed up doing, the only way it's coming out in one bit is via taking the wind off; that's a lot of faff.
I'm not planning on deep wading but I'm hoping for a bit of a performance improvement. The original intake is quite restrictive compared to the Nugget Stuff one. Not been out for a test drive yet. I'll report back my findings. https://www.nuggetstuff.com/product/defender-puma-sealed-airbox/ |
![]() Click image to enlarge In the middle of nowhere some distance off the NLAND250. Truly epic drive along single track roads. A great area to visit and a Defender is the ideal vehicle, the single track is very broken in places. https://northumberland250.com |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1631 ![]() ![]() ![]() |
Hi Steveww, that is a stunning photo
Otterburn military firing range. They publish the firing times, obviously don't go in when they're shooting
![]() Click image to enlarge Just fitted a new from t bumper which is very similar to the old one, except it's not all rusty. It will not rust because it's stainless steel from Uproar 4x4. I fitted in the Nolden lights from the old bumper. Very impressed with the quality. Scott from Uproar is very helpful and great to deal with. |
Very nice. I do like the dual bumper lights
The outer pair are DRL and the inner pair are spot lights which can come on the high beam.
Lizzy has been very handy the last few days. The valley roads around here are quite deep with flood water, not a problem for a Defender.
I spent some time in the workshop fabricating emergency internal bed. I have the Bundutec roof top tent which is great but like all roof tents not so good in high winds. When we did the NC500 a storm blew through with 60mph winds. Fortunately we were able to find alternative accommodation for the stormy night. If that had not been the case it would have been a very uncomfortable night. I now have an extra board and some brackets that create an emergency sleeping platform inside. Pictures to follow... |
![]() Click image to enlarge Fitted a new cubby box from Exmoor Trim. It's a bit of a faff to swap over all the wiring when you have the XS subwoofer installed also the new box is longer than the original making for tight clearance when folding down the rear seats. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 927 ![]() ![]() ![]() |
The premium seats are in another league over standard and XS spec. They really uplift the interior. I’d love a pair. 2008 2.4 110 Utility Station Wagon XS.
Yearly service completed with oil changes, grease applied, etc.
I noticed that the fresh air duct from the wing to the heater is not a snug fit where it meets with the heater. There is a foam gasket but on mine there is quite a gap. I checked that the drain hole was clear then wedged some dense foam between the duct and the inner wing. This has closed up the gap and resulted in less engine noise inside the cabin. It should also help if we ever see the sun again such that there will not be any hot air from the engine bay entering the heating/cooling system. ![]() Click image to enlarge |
There has been a bit of a clonk / rattle from the rear of Lizzy when going down farm tracks. Something was obviously a bit loose somewhere. Finally tracked it down to the rear sliding windows; a well know issue with Defenders. I cut some cable ties to size and used them as packers to hold the sliding glass in place. I've ordered new felt channels top and bottom from LR Parts and these should be a more permanent fix when they eventually arrive.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2252 ![]() ![]() |
See this topic on ways to rectify the issue https://www.defender2.net/forum/topic75787.html?highlight=heater |
