Home > Maintenance & Modifications > Applying ACF-50 advice. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 784 |
Continuing the above post..
What is ideally like is a clear’ish finish - I believe lanoguard offers this type of finish. The Dintriol finish is a bit off putting for me, I don’t like to see everything covered in a black underseal. 2008 2.4 110 Utility Station Wagon XS. |
30th Jan 2022 1:02pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5612 |
Dint do do a clearer version not just the black for your info
30th Jan 2022 1:45pm |
That’s brilliant news! I had no idea. That’s definitely something I’ll be looking at then!
Cheers 2008 2.4 110 Utility Station Wagon XS. |
30th Jan 2022 1:50pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
ACF50 is pretty carp at staying on IMO, it lasted all of a week on the underside of the farm truck
30th Jan 2022 2:11pm |
karlp606 Member Since: 19 Aug 2021 Location: Hull Posts: 298 |
Mine had Dinatrol underneath on the main chassis areas - its still visible nearly 3 years later only just starting to come off.
You could use Kurust on the visible areas that dries clear. |
30th Jan 2022 2:38pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1774 |
ACF is great sprayed up behind cappings, where panels overlap etc - anywhere it will be left to sit with no abrasion from water spray etc.
I use Dinitrol and rate it - others use different makes and prefer those, I've even spoke to someone recently who swears by Waxoil - you pays your money.... HTH Keith |
30th Jan 2022 6:07pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3359 |
I've done all of my trucks in Lanoguard now. It dries nicely after a few days and won't leave you covered in gunge if you're crawling around under the truck. You can jet wash the underside after it's dried and it will stay on.
Takes around 30 minutes to apply on you've jet washed all the crxp off underneath Isn't messy either while you're applying it and it leaves a strangely pleasing odour! At £50 a pop it isn't going to break the bank either, I'd recommend reapplying it annually. |
30th Jan 2022 6:11pm |
Is the Lanoguard something that you can spray under the arches/body under the arches also? Or mainly chassis only? 2008 2.4 110 Utility Station Wagon XS.
30th Jan 2022 6:47pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1952 |
For any surface rust on chassis etc you could clean , degrease, dry then use bilt hamber hydrate 80. Then potentially prime with electrox then paint with corroless all in one or bilt hamber epoxy mastic.
For a clear wax you can use bilt hamber dynax uc. https://bilthamber.com/product-category/anti-corrosion/ Yes you guessed, I like bilt hamber products, and corroless paint Ps . I’m getting interested in lanoguard as the main chassis wax as well now, cost and ease of application appeals to me. |
30th Jan 2022 7:18pm |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 969 |
I used ACF50 on our three Bloodbikes over winter last year, it does protect them very well but attracts all the crap off the road and needs a hot jet wash to remove it in the spring.
Before application make sure you soak the containers in hot water to make it flow Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
30th Jan 2022 7:19pm |
Lanoguard: Spray it anywhere, chassis, arches, underbody, electrics...
Fantastic help all. Thank you 2008 2.4 110 Utility Station Wagon XS.
30th Jan 2022 8:17pm |
here's a couple of pics under my lightweight straight after applying the lanoguard.
30th Jan 2022 11:10pm |
Well...my first order has arrived...ACF-50. I think I over ordered though... 4 litres 😅 but I guess it’ll last a long time.
Next purchase is Lanoguard I think. Then it’s a job to tackle after winter. 2008 2.4 110 Utility Station Wagon XS. |
31st Jan 2022 3:54pm |
