- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Balvaig
You could treat a jumbo jet with 4 lt.
It goes a long way - I treated all cappings and riveted areas around the rear door, all hinges, front window brackets and any other jointed areas on bodywork using a 400 ml spray can multiple times. It soaks well into the joints and you can wipe off the excess from the surface bodywork.
No sign of corrosion in these areas after 5 years.
31st Jan 2022 4:16pm |
