Home > My Defender > The german big black 110
Page 2 of 2 <12
roamfree
Germany 2009 Defender 110 Puma 2.4 SW Santorini Black
It's been a while, so about time for an update! In the last two months quite a bit happend, so let's get going!
I...
..hit a milestone - still hurts a bit loading kilometres on this bad boy, but if it's not for driving what is it for?!
...had to fight some corrosion
...did some beauty shots
...upholstered the cubbybox cover after falling in love with the material because friends of mine did redo their rear door card with it. *not jealous at all there Rolling Eyes*
I think it look quite the part, doesn't it?! No I will only need to dye that seat cover black Very Happy
...did change the transfer case oil. This one was actually high up on my list. I have a leak somewhere in the transfer box. Actually there probably are multiples. I have some oil in the handbrake drum, and also coming somewhere from the front of the transfer case.
Since the last oil change was nearly a year ago and there constantly were some drops of oil under the car I was getting quite worried about the amount of actual oil left in the thing.
Turns out that was very much warranted, only about 2 liters remained in the transfer case by now.
There was a bit of metallic residue with a few bigger pieces. Honestly I have no idea if this is worrisome and I should start saving for a new transfer case or if this is totally fine. Maybe some more knowledgable forum members can shine a light on that? Whistle
Then I had quite the setback, it appears after I fixed all the leaking from the alpine windows and cappings, that now the roof itself decided to leak, resulting in wet carpets and water in the car once more Big Cry
But that will have to wait till after the vacation. In preparation for that there was some new addition to the big Censored :
Old 'new' rear ladder, kindly donated by an ex-defender owner and upcycled with some trusty Korrux paint.
New awning, so we can have our coffee without being soaked or burned by the sun Thumbs Up
Extended family already used the occasion while I did the transfer case oil change to try out the new setup
Last preparations for the vacation then were a service of the aircon, specifically refilling the coolant. I very much missed a working aircon when travling to various festivals this summer, now I decided I wouldn't be burned alive on the motorway once more. So my legs instead don't get freeze dried this time around I got myself some heat deflector. Couldn't bring myself to drill, so now it lives held on by double sided tape. I am curious to see if it will survive the upcoming vacation this way.
Well, turns out all of this wouldn't have been needed, Denmark is gonna provide the best of rain weather for us next week! Better prepared than sorry I guess Rolling with laughter
I also got myself a crafter/sprinter jack, since I had to notice, that the LR spindle jack will no longer work on my Defender, at least not for the front. The bolts that hold the mounting plate for the winch cover up the jack holes under the front bumper. Let's hope I won't have to test the new jack for functionality any time soon!
That concludes my summary of the last two months. In this period the big black was at the shop only twice! What an accomplishment... First time around the brakes where seizing up, second time around it was only the air con service luckily. I kind of fear that I soon might be back to the mechanics though, might be imagination or not, but I think I overheard some more brake noises... Might be because I drive way to little...
Anyhow, I will keep you all posted what the time brings Thumbs Up
Post #960008 29th Jul 2022 11:58pm
Dinnu
Unfortunately the transfer boxes on Pumas do not seem to last as long as they did on the predecessors.
There could be several reasons to why. The Puma has very high cyclic loads, and perhaps made worse by the thicker, hence stiffer half shafts.
The oil leak from the front (if by front you mean the face where it mates with the gearbox adaptor housing) is generally caused by the intermediate shaft O ring that looses its ability to seal as it sets to a squarish profile over time.
However there is also a possibility that the hole for the intermediate shaft in the aluminium casing to go oval and a new O ring would not solve the leak. But there are also upgrades for that - just google "LT230 sleeve casing" either by getting a modified casing, or getting just the sleeve and modifying your case and installing locally. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #960015 30th Jul 2022 7:08am
Honeyman
Netherlands 2011 Defender 130 Puma 2.4 HCPU Sumatra Black
If it’s any consolation, this is what the drain plug on mine looked like yesterday….
 2011MY 130 HCPU: daily driver
1979MY RRC 2-door: on the drive, in the garage & in a shed - all at the same time.
Post #960026 30th Jul 2022 10:39am
roamfree
My condolences honey man, that looks bad indeed! Guess I was lucky after all 😆
Hope yours will be fine!
Post #960214 1st Aug 2022 4:34pm
Honeyman
Thanks! It will be fine eventually - made a start at least
Post #960227 1st Aug 2022 5:50pm
Caterham
/\ I think its possible for these things to be fine eventually, after much, time, effort and money.
Assuming of course you set the bar very low as to what fine is Rolling with laughter
Post #960245 1st Aug 2022 7:37pm
roamfree
It's been a while! Just as with every Defender there have been countless ups and downs this past one and a half years. All in all I am quite happy with the big black, but there are of course the next problems looming on the horizon. But before we get into the nitty gritty let's enjoy the more pleasurable experiences of 2023:
It starts with travel preparations in May:
U-Joints in the front were due
While it was up on the lift, I noticed that it was leaking from the transfer case...
Defender on the lift
So the front output flange and corresponding seal was changed...
New front output flange of the transfer case
... that helped a ton, but still the transfer case is not 100% dry.
A bigger journey was upcoming so fluids were in order:
changing the front diff oil, and violating the new diff guard in the process
Since we wanted to drive in convoy, a radio was needed. But where to place the antenna? I didn't want to do any drilling... so a custom mount was to be fabricated:
custom antenna mount in the making
finaly product and freshly mounted antenna
And on the journey went:
western alps 1
western alps 2
Denmark
Norway
And of course it wouldn't be a defender without a water leak, what a way to start 2024!
leak 1
But I don't think it was this clean since August, so thats something I guess Laughing
leak 2
Currently dismounted the rack since I have some corrosion on the alpines and was thinking of tackling it. But I might wait till summer honestly...
a clean Defender in the city
I gotta say though, I kind of love the clean aesthetic of the defender without the roof rack.
Post #1025242 19th Feb 2024 10:08pm
L110CDL
Thank you for your update and the pics on " big black " great your still enjoying defender life and it wouldn't be the same if you were not tinkering on it Wink
Hope you get the water leaks sorted this year Thumbs Up Clayton.
Keeper.
Post #1025246 19th Feb 2024 10:26pm
Looks good! first time I’ve seen your thread, there is always something to do with a Defender, the works never ends. Laughing Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1025257 20th Feb 2024 12:05am
Waka56
Germany
Nice big black! Got a big white recently, which needs a fair bit of work. Might see you around in Hamburg Smile Making my Defender great again. (Or trying to at least xD)
Post #1028894 21st Mar 2024 7:41pm
roamfree
Thanks folks!
The water leak indeed seems to be sorted for now @L11CDL. Lets pray that it stays that way, Hamburg is showing itself in its greatest glory again at the moment.
However I seem to have some corrosion on the alpines which will need fixing... and thereby possibly needing to respray the whole roof. Guess there's always something, just as you said @custom90!
Speaking of things that need fixing: Three weeks ago the ignition switch decided to die, so that needed sorting:
With the steering wheel off I decided to finally mount that christmas gift and get rid of that ugly Raid logo:
The wire-loom for the rear passenger doors was broken and thus my central locking was done for. So that was the next job that I tackled.
Unsure about the alpines, but besides those I really hope that this is it with major suprises this year. I would love to spend the money on some fine new upgrades instead of repairs for a change Laughing
@Waka I'll keep my eyes open! Always happy to connect to other Defender drivers Thumbs Up
Post #1029643 28th Mar 2024 6:16pm
L110CDL
Nice bit of maintenance work your carrying out on the 110 Thumbs Up
You have to be patient with finding the money to spend on upgrades, that time will come one day for you Wink Very Happy Clayton.
Keeper.
Post #1029678 28th Mar 2024 10:23pm
roamfree
Transmission and clutch maintenance
I cannot believe it's been already a year since an update here. It's about time! And what better occasion could there be than a little (big) maintenance.
Soooo let's start with a little recap of the last year.
After the water leak beginning of 2024 it was found that the leak was from the windscreen seal, so the windscreen was replaced. Conveniently the car was in the workshop already, because the starter decided to die on me a few days earlier.
In September service was due. I had noticed that there was a lot of black smoke coming from the exhaust, so it was investigated. Turned out a seal in the turbo had blown and it needed replacing. Inspection at the garage furthermore showed that the rear brakes were toast by this point. So turbo and brakes were due. Since the car was at the indie anyway, I was dumb enough to let them tackle those... I sure regretted not doing it myself after receiving the bill.
Now as if that was not already enough, the transfer case started leaking from the intermediate shaft and by now I could hear the springs in my clutch plates rattle. After the last visit still left me grinding my teeth, I was to make a decision. Do it myself or spent another fortune that I did not really posses.
One could say 2024 was a rather turbolent year, even though I did not drive all that much sadly. I wanted to change that and take the Defender finally overlanding again this year. Soooo, transfer case and clutch needed tackling!
After pleading with friends, they were kind enough to repark their own Defender and make space in their garage for me. This is the first major operation I was about to conquer, having no engineering experience under my belt what so ever. I am an IT guy after all. So this was quite daunting to me... However, before I could start with the tc and clutch, one more obstacle decided to pop up. See, my MOT was due this January. Shortly before Christmas I got a call that a MOT appointment became free and if I didn't want to take it.
I knew of the leaking transfer case, but thought nothing a little brake cleaner before the inspection couldn't fix. So in I went. Weeeell, as it turned out the big one was not burning all its Diesel, leading to nearly failing the emission test. By sheer luck I came through, but I knew something was afoot.
After some research, I came to the conclusion that at 120k kilometers, it was possibly the injectors on their way out. So, those needed tackling as well. What a job to start into the year to! And thus, I booked myself in at my friends for most of January.
The operation is about to start!
First up?
injectors)
labeling everything up
Injectors sure not looking to good anymore after 120k
rockers not looking to shabby
camshaft and roller on the other hand not locking to good there... Do you folks think this needs addressing?
all new injectors going in
a quick test drive revealed some problem with cylinder 4. That'll need sorting soon enough...
checking for leaks using some baby powder
Sooo turns out the leak from the injector was not the injector at all, but the fuel line. I got lucky there driving round with a leaky line. After changing the line is was problem solved!
VCV
Since I was dealing with some kind of fueling issue and the Defender was idling quite roughly as well as smoking too long after acceleration, I thought replacing the VCV might be a good thing to do. Universe had other plans though...
Previous owner already changed the vcv at least once. The right bolt was so tight that I stripped the screw... Since I have not dared touching it again for fear of ending up having to remove the whole bloody pump in the end...
intermediate shaft)
Because the transfer was coming out in any case, I finally had the opportunity to fit the LOF MT82 Extreme Output shaft that I was driving around for coming up on year at this point.
This thing was beyond rusty, so good I changed it and now have peace of mind.
LOF output shaft in all its machined glory.Take up is much much smoother now after the change.
new clutch)
turned out the previous owner put a transit 4x4 clutch in
sadly the previous workshop must have put the accessible bolts down at the button in with an impact gun. Threads were stripped and one screw broke in the process of removing the gearbox
Luke's sticker saving my day... previous indie workshop was just as unaware as me of there being different spec flywheels around. Back then I trusted their judgement that the clutch was still fine and had it reassembled after a slave cylinder failure... That was about 50km after I had acquired the car Rolling Eyes
new powerspec clutch in after sorting out a new clutch cover with Luke.
I had hoped of getting away with not removing the starter (it was stuck), but damaged the seal when reassembling Whistle
Sooo I had to get creative and reglue it in situ
Final step: relocating the clutch hose bracket. Shoutout to @ickle (Keith) and @custom90 for bearing with my stupid questions!
transfer case)
not so nice finding after having the tc removed. The center diff seems on its way out...
big chunks of copper in the input housing, likely coming from the thrust washer in the center diff.
the gears itself still look good
new intermediate shaft and o-rings going in
...and because I couldn't leave the box this time around some silicone...
Having been on my list for ages, a high cap sump went onto the tc when it was reassembled.
Not what I had hoped for. Since I do not have the money to have it rebuild and I do not trust myself with rebuilding it myself, for now I'll have to live with it. Guess an ATB will need to replace the by then probably worn center diff when I can afford having the box rebuild. Let's hope soon Big Cry
so where do we stand?
Well, I have not been able to get the gear selection to be quite as perfect as I would have hoped, but it still is a world of a difference with the new clutch and the intermediate shafts. Shifts are crisp and I do have to be way less careful in order not to produce the typical backlash in the drive line. Makes for way more comfortable driving Mr. Green
Nooow however, the next problem looms on the horizon. Now already for the third time, my ABS and TC lights stayed on and the nanocom reports a "shuttle valve switch failure (13-07)". With me not being much of a electronics guy, I fear the next trip to the indie is on the horizon... but for the moment being, I will allow myself to be proud of the operation undergone succussfully Mr. Green
Thank you again for everyone in this forum that enables even noobies like me to work on these beautiful cars. I would not have dared without all the great guides, tips and the sheer amount of knowledge collected here.
Cheers folks!
Post #1062645 11th Mar 2025 9:06pm
Page 2 of 2 <12
