![]() | Home > My Defender > The german big black 110 |
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 834 ![]() ![]() ![]() |
Welcome, one bit of advice don’t build a todo list, it never goes down only gets bigger, but they are great vehicles and I see yours is teaching you who is the boss Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Thats a very clean, smart looking Defender
![]() Regarding the rear door, and the shattered glass, I see in one of the pics that there was some welding and the edge is not so smooth? I do not know if I see correctly. FYI, tempered glass is very strong, difficult to break if you hit it perpendicular to the surface, however it is extremely weak if stress is applied on the edge. The seal is kind of an H profile, and there should be rubber between the door flange and the edge of the glass. But if there are sharp projections in the metal, I guess would be easy to perforate through the rubber and apply point stress on the edge of the glass. So make sure you file the edge of the door flange smooth before installing a new glass. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
Welcome Felix with a nice 110 you got there and your joining in well with defender ownership
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
roamfree Member Since: 19 Jan 2022 Location: Northern Germany Posts: 24 ![]() ![]() ![]() |
Yes, that is good advice haha! I really should take that to the heart, but I am afraid it's already to late for that... ![]()
Yes I did grind it down quite a bit and there was no damage to the rubber seal whatsoever! However, with the added stress of offroading it might very much have been it... Though luckily I have been fine since, let's hope I stays that way! ![]() Click image to enlarge
Thanks man, much appreciated! On the weekend I sadly noticed that I have had a water leak in the rear left of the Defender an that water had pooled up under the carpet... so I guess that's the job for the next weekend sorted out. ![]() Click image to enlarge While removing the rear door sill of course I broke 4 out of 7 screws... I hope I can get them out with a pair of pliers and some luck, because I don't feel like drilling them out will be an easy task. Let's hope for the best! While at it I also removed the number plate holder, which sadly is mounted to the rear cross member, which I plan on respraying with Brantho Kurrox nitrofest. ![]() Click image to enlarge Let's just say I was very much impressed with the wiring work the previous owner had done ![]() |
Oh....
![]() ![]() Wow, haven't seen such a half arsed wiring bodge since my Step Father moved to Canada ![]() |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1111 ![]() ![]() ![]() |
Welkom to zee club, also from Gerrmany
![]() I'd "talk" to the previous owner about his negligence... ![]() Good thing is: it seems as if you've done most of the "usual" fixes already. What region are you living in? (I live between BS and GS) |
Thanks man! Heck, I would love to have a chat with that bloke as well! There is quite a bit of stuff messed up with the car... While I am not a mechanic myself, even I see that things could have been done better. My favorite so far? A freakin piece of wood in the air intake for the heater! Like why?! ![]() ![]() Click image to enlarge I am from the greater Hamburg area ![]() |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2273 ![]() ![]() |
perhaps the previous owner thought it was the ideal place to store a wheel chock, I would look on the other side to see if there is a matching one in that wing
February saw quite some work for the big black. First step to strip the carpet after the water disaster in January. Now parked in a watertight spot and emptied out I could get to finding those leaks:
![]() Click image to enlarge After some fun with the water hose I found leaks on the skylights and the cappings. But nothing a little Sika couldn't fix luckily! ![]() Click image to enlarge ![]() Click image to enlarge I got to say I way a bit nervous but in the end I think I am quite pleased with the result: ![]() Click image to enlarge Sadly I couldn't save the rear door sill. I had to order a new stainless one from Nakatanenga. They promote it as having slightly offset holes, which I need since I could not manage to drill out the snapped old ones. Bloody ![]() As it was getting late and I need to drop of the big black at the workshop I didn't put in the carpet correctly and will need to get that sorted. Before it went off though I had to use the opportunity and respray the rear crossmember: ![]() Click image to enlarge ![]() Click image to enlarge Currently the big black is in the workshop getting new tie rod end fitted after they missed them the last time ![]() ![]() |
Great work your doing on the 110, all this work will be better in the end as you will be driving it more than working on it
It's been a while since the last update, so let me tell you what I have been up to and what the big black has thrown at me in the last months!
After finally having a (somewhat) waterproof car I sent the Defender over to my mechanic to do the annual service. It was noted that the track rods and uj's in the rear prop shaft were due for change. Since the track rods were still under guarantee after having been replaced only a bit over a year ago I was planning on getting that done by the workshop. I had since switched my garages, so I had to pick up the car and get it other to the old garage that did the changing of the track rod ends before. Meanwhile I ordered new UJs, since I planned on doing these myself, didn't look to difficult in the videos. Boy was I wrong. But more on that later... So the old garage basically told me the track rod ends were just rusty (S***part ![]() ![]() Click image to enlarge Defender rolling in to my 'workshop' Removing propshaft was no problem and the first UJ went just fine: ![]() Click image to enlarge But the second one I was really struggling with. First the old uj jamed when I tried to push it out. After that was overcome I did fit the new one. But it just didn't quite fit. I could get the circlip in, but everytime I did, the uj just became super hard to move. So hard, I actually didn't want to risk mounting the propshaft that way... Frustration was stetting in. ![]() Click image to enlarge ![]() Click image to enlarge Measuring the old and new ujs, the new one came in a fraction of a millimetre wider At one point I was seriously doubting if I had ordered the right uj for the propshaft. But they were close enough in dimension and the part numbers were right. So where was I going wrong? I pressed out the new uj again at one point, sadly damaging the sealing cap... ![]() ![]() Click image to enlarge Of course, parking rules were happily obliged! ![]() Click image to enlarge The jacked up Defender barely had a centimeter left before touching the ceiling of the garage So after two weekends, lots of swearing and back and forth, the propshaft finally went back in. And to my surprise everything was actually fine. ![]() ![]() Click image to enlarge All new and shiny! Besides there were only some minor jobs done. In loose order: ![]() Click image to enlarge Hood came of for some new bushes in the hinges ![]() Click image to enlarge Touched up some paint where the A-bar rubbed against the plastic. I will need to get a new radiator grill eventually ![]() Click image to enlarge ![]() Click image to enlarge Played with some 3d printing, since I want to replace my simple rocker switch for the winch with a proper oem switch and I want some nice bezel for it And fiiiiinally after over a year with the Defender: I have the correct number plate format! I just could bare the old one any longer ![]() ![]() Click image to enlarge Next jobs a piling up fast though... I need to get the track rod ends sorted, because frankly my old garage just screwed my over on those. They are toast and they probably knew it, just didn't want to align the track... After all those were 10 euro britpart track rods, so it can't have been about the money for parts... Still need to decide if that is something I actually wanna tackle myself or let the garage handle. Also, my rear shocks seem to be done. I have a metal on metal clonk everytime I drive through a hole or jump a bit in the rear compartment. Might be shocks themselves or just the bushes. Not sure, and I don't know how to tell the difference. Furthermore I am basically just waiting for the clutch to fail, since I have the rattle of death. Gonna be an expensive summer I guess ![]() |
While relocating the number plate lighting, I removed the trim on both sides of the rear door. While in there I noticed that I have a badly corroded plug which I couldn't quite tell what it was for. Maybe someone more knowledgable than I would know? This is the rear right hand side cable harness coming up from the chassis into the interior:
Plug on the right side is prob the 12v supply that’s there.
As for the track rod get the kit from Gwyn Lewis “sumo bars” with the new joints and have a go. I recently did mine they were not that hard to change, main issue I had was having to purchase the spanners in sizes I did not have before. Searching for my first Defender...and started just as Covid hit, so talk about timing. 5 months after starting the search I found it, and here is the details |
Thank you for the update
