Home > Puma (Tdci) > Rattle noise when main gear in neutral |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
check out the clutch threads on here that sounds like a rattle from the clutch or the transmission caused by the clutch
what clutch you got and how many miles on it DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
8th Jan 2022 7:26am |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2419 |
most likely clutch I had same issue 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
8th Jan 2022 9:52am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17467 |
That is most likely to be your Defender telling you it needs a new driven plate, a very well known issue with the TDCi especially with the earlier clutches. There are many threads on here on the subject.
Incidentally you are confusing "in" and "out" when talking about the clutch - "in" means engaged (pedal up), and "out" means disengaged (pedal pressed). It is amazing how many people make this mistake. |
8th Jan 2022 1:14pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 588 |
As above. Worn or loose/broken spring on clutch driven plate. I have a similar video of mine when it was rattling but struggling to post it
8th Jan 2022 5:37pm |
