Home > Puma (Tdci) > Rattle noise when main gear in neutral
fatduckling
Australia
Hi
My 2011 Defender 110 seems to have a rattle noise when the main gear is in neutral. I've had the issue for like two years and I'm not too sure what the issue could be.
Some notes:
* The rattle noise only occurs sometimes (maybe 1-2 times per trip).
* It only occurs when the main gear is in neutral and the clutch isn't depressed
* The sound stops when either the clutch is depressed (as shown in the video) or if the main gear is not in neutral
* Seems to occur more frequently when the car is parked in a hill as opposed to flat ground (like shown in video)
Skip to 12 seconds in to hear the noise:
Any ideas as to what the issue can be would be highly appreciated,
Thanks!
Post #936777 8th Jan 2022 5:26am
LR90XS2011
check out the clutch threads on here that sounds like a rattle from the clutch or the transmission caused by the clutch
what clutch you got and how many miles on it DEFENDER 90 TDCI XS,
Post #936781 8th Jan 2022 8:26am
Welshsurferdude
Wales
most likely clutch I had same issue 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #936792 8th Jan 2022 10:52am
That is most likely to be your Defender telling you it needs a new driven plate, a very well known issue with the TDCi especially with the earlier clutches. There are many threads on here on the subject.
Incidentally you are confusing "in" and "out" when talking about the clutch - "in" means engaged (pedal up), and "out" means disengaged (pedal pressed). It is amazing how many people make this mistake. Very Happy
Post #936825 8th Jan 2022 2:14pm
Siwynne
As above. Worn or loose/broken spring on clutch driven plate. I have a similar video of mine when it was rattling but struggling to post it
Post #936862 8th Jan 2022 6:37pm
