![]() | Home > Td5 > Battery light |
Have you had a look at it? might be full of mud. checked the battery box? might be full of water.
Mullen Member Since: 31 Aug 2011 Location: West midlands Posts: 93 ![]() ![]() |
Yeah had a look at the alternater, theres signs that muddy water has been there but its not thick of it! There is signs that water has been in the bottom of the battery box but only enough to cover the floor of it
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5834 ![]() ![]() |
Stick a hose in the side of it, wash out as much mud as poss.
Worth a try Andy |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
^^^ What he said.
then a good dose of WD40 |
Il give it a try, if it is the alternater, whats peoples thoughts on recon units or shall i go for a new one?
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
use a multimeter to check the battery voltage with the engine running, it should be around 14 volts. This will tell you for sure if the alternator is smoked.
Pom |
