Home > Td5 > Battery light
Mullen
Battery light
Went to LRO show today and after going through some water on the off road course the battery light came on, got 90 miles on the way home and died! Take it my alternaters died?
Post #88539 11th Sep 2011 2:15pm
BigMike
Have you had a look at it? might be full of mud. checked the battery box? might be full of water.
Post #88546 11th Sep 2011 2:58pm
Mullen
Yeah had a look at the alternater, theres signs that muddy water has been there but its not thick of it! There is signs that water has been in the bottom of the battery box but only enough to cover the floor of it
Post #88548 11th Sep 2011 3:03pm
landy andy
Stick a hose in the side of it, wash out as much mud as poss.
Worth a try
Andy
Post #88567 11th Sep 2011 5:32pm
^^^ What he said.
then a good dose of WD40
Post #88589 11th Sep 2011 7:34pm
Mullen
Il give it a try, if it is the alternater, whats peoples thoughts on recon units or shall i go for a new one?
Post #88593 11th Sep 2011 7:54pm
pom
use a multimeter to check the battery voltage with the engine running, it should be around 14 volts. This will tell you for sure if the alternator is smoked.
Pom
Post #88620 12th Sep 2011 6:35am
