Home > INEOS Grenadier > Grenadier Axle |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1440 |
It certainly appears to be a Carraro axle, looks suitably heavy duty and has 6 stud hubs. It has similar suspension geometry to the 2A prototype that had a modified and trussed axle, probably used just to get the prototypes up and running. Hence the 2A's used 5 stud wheels.
2A vehicle, Click image to enlarge Click image to enlarge The diff housing on the 2A looks very much like this Dana 44 from a Jeep Wrangler Rubicon. |
11th Oct 2021 11:14pm |
There's some good detail in that video ~ assuming the 2b axles make it into final production... a Salisbury type diff?
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
22nd Oct 2021 2:40pm |
County V8 Member Since: 07 Jun 2021 Location: UK Posts: 147 |
Will have an Eaton Locker in it
Elocker |
22nd Oct 2021 2:57pm |
Where are you getting that from?
23rd Oct 2021 7:32am |
Click image to enlarge Click image to enlarge The Brembo brakes will look good hung on that axle think of the fun you could have with the Brembo parts catalogue . |
23rd Oct 2021 9:41am |
The Antonio Carraro SRX 5800/6800 Tora narrow tractor was recently recognized in the EIMA Technical Innovation Awards program. This highly specialized narrow tractor accesses hard-to-reach locations with help from Dana’s high-precision gears, shafts, and a bevel gear set.
https://www.facebook.com/DanaIncorporated/...887016556/ It appears from the above, that Carraro are already using Dana components in their axles. It would make sense to use an existing differential and base a new axle design around that. So my guess is, we are either looking at a beefed up Dana 44 or Carraro's version of a Dana 60 axle. E lockers are available off the shelf for both axles. A wide choice of gear ratio options are also available for heavy duty towing or large tyre use. Dana components would also help from a world wide spares availability perspective. |
23rd Oct 2021 2:42pm |
Can you hear me waving? |
23rd Oct 2021 3:36pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4227 |
I don’t think Antonio Carraro tractors and Carraro Group are related at all. 2007 110 TDCi Station Wagon XS Last edited by Bluest on 23rd Oct 2021 4:00pm. Edited 1 time in total |
23rd Oct 2021 3:51pm |
Eibach springs Frapp links Nolden front lights BASF paint Pilkington glass. |
23rd Oct 2021 3:57pm |
Carlos Fandango wheels I heard, but only for the Uzbekistan market model. 2007 110 TDCi Station Wagon XS
23rd Oct 2021 4:00pm |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
I doubt it will get a dana60 center section in the front. This makes no sense with just 32"s. Dana 44 will be great though. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
23rd Oct 2021 4:05pm |
Maybe not. 2 Tractor manufacturers, both called Carraro, based in Campodarsego, Italy. Not sure what the history is there. https://www.carraro.com/en/products-and-services/tractors https://www.antoniocarraro.it/en/catalogue Edit, Carraro Group was founded by Giovanni Carraro and first manufactured agricultural equipment, seeders, in 1932. The first tractor was built in 1958. Antonio Carraro separated from his brothers in 1960 to form the Antonio Carraro company. In 1977 Carraro Group decided to transfer the production of tractors to Rovigo. Last edited by DSC-off on 23rd Oct 2021 4:16pm. Edited 1 time in total |
23rd Oct 2021 4:07pm |
I thought they were using Maxion wheels steel and alloy.
But the Carlos Fandango would make a good option. |
23rd Oct 2021 4:09pm |
Ahh, got it: |
23rd Oct 2021 4:26pm |
