Home > INEOS Grenadier > Grenadier Axle
County V8
Grenadier Axle
Is this the Grenadier axle someone from Carraro said yes what do you think?
Its from this video of 2B tour in Italy at the Carraro factory about 2.00 mins in
&t=131s
Post #925309 11th Oct 2021 3:19pm
DSC-off
It certainly appears to be a Carraro axle, looks suitably heavy duty and has 6 stud hubs. It has similar suspension geometry to the 2A prototype that had a modified and trussed axle, probably used just to get the prototypes up and running. Hence the 2A's used 5 stud wheels.
2A vehicle,
The diff housing on the 2A looks very much like this Dana 44 from a Jeep Wrangler Rubicon.
Post #925368 12th Oct 2021 12:14am
There's some good detail in that video ~ assuming the 2b axles make it into final production... a Salisbury type diff?
Post #926782 22nd Oct 2021 3:40pm
County V8
Will have an Eaton Locker in it
Elocker
Post #926785 22nd Oct 2021 3:57pm
Where are you getting that from?
Post #926839 23rd Oct 2021 8:32am
County V8
The Brembo brakes will look good hung on that axle think of the fun you could have with the Brembo parts catalogue .
Post #926852 23rd Oct 2021 10:41am
DSC-off
The Antonio Carraro SRX 5800/6800 Tora narrow tractor was recently recognized in the EIMA Technical Innovation Awards program. This highly specialized narrow tractor accesses hard-to-reach locations with help from Dana’s high-precision gears, shafts, and a bevel gear set.
https://www.facebook.com/DanaIncorporated/...887016556/
It appears from the above, that Carraro are already using Dana components in their axles. It would make sense to use an existing differential and base a new axle design around that.
So my guess is, we are either looking at a beefed up Dana 44 or Carraro's version of a Dana 60 axle.
E lockers are available off the shelf for both axles.
A wide choice of gear ratio options are also available for heavy duty towing or large tyre use.
Dana components would also help from a world wide spares availability perspective.
Post #926868 23rd Oct 2021 3:42pm
Elocker
Can you hear me waving?
Snigger
Post #926871 23rd Oct 2021 4:36pm
Bluest
I don’t think Antonio Carraro tractors and Carraro Group are related at all. 2007 110 TDCi Station Wagon XS
Post #926874 23rd Oct 2021 4:51pm
County V8
Supacat wrote:
Elocker
Snigger
Eibach springs Frapp links Nolden front lights BASF paint Pilkington glass.
Post #926875 23rd Oct 2021 4:57pm
Bluest
Carlos Fandango wheels I heard, but only for the Uzbekistan market model. 2007 110 TDCi Station Wagon XS
Post #926876 23rd Oct 2021 5:00pm
diduan
Bulgaria
I doubt it will get a dana60 center section in the front. This makes no sense with just 32"s. Dana 44 will be great though. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #926877 23rd Oct 2021 5:05pm
DSC-off
Bluest wrote:
I don’t think Antonio Carraro tractors and Carraro Axles are related at all.
Maybe not. Confused
2 Tractor manufacturers, both called Carraro, based in Campodarsego, Italy.
Not sure what the history is there.
https://www.carraro.com/en/products-and-services/tractors
https://www.antoniocarraro.it/en/catalogue
Edit,
Carraro Group was founded by Giovanni Carraro and first manufactured agricultural equipment, seeders, in 1932. The first tractor was built in 1958. Antonio Carraro separated from his brothers in 1960 to form the Antonio Carraro company. In 1977 Carraro Group decided to transfer the production of tractors to Rovigo.
Post #926878 23rd Oct 2021 5:07pm
County V8
I thought they were using Maxion wheels steel and alloy.
But the Carlos Fandango would make a good option.
Post #926879 23rd Oct 2021 5:09pm
County V8 wrote:
Supacat wrote:
Elocker
Snigger
Ahh, got it:
Post #926885 23rd Oct 2021 5:26pm
