Home > My Defender > Grishuna
Page 3 of 6 <123456>
Timo
Canada 1984 Defender 110 300 Tdi SW Alveston Red
BEFORE:
During:
AND AFTER
Nothing like three coats of POR-15. It is a bit glossy with the lighting and I don't think it will be quite that shiny outside (or will stay this clean....)
I am going to give it a day to harden then have them mounted on Wed. I will post another shot with finally the correct tyre size.
T_ Series II in pieces
1984 Defender 110 (3.5l V8 now 300TDI)
Post #142671 1st May 2012 3:01am
LR90XS2011
There is a 110 on Piston Heads at the moment that reminds me a bit of yours V8 110 1985 simular brown colour DEFENDER 90 TDCI XS,
Post #143471 5th May 2012 5:50am
greyback
1989 Defender 110 200 Tdi PU Bonatti Grey
that is such a cool truck.
love it.
Post #143709 7th May 2012 12:55am
Timo
It looks so much better with the new tires (215->235s) and the rims painted
t_
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Series II in pieces
Post #144179 9th May 2012 6:45pm
Sorry Timo, but those rims should be limestone, IHMO.
Changing the subject, that's one hell of a tow bar you've got there. What do you tow with it? Darren
Post #144182 9th May 2012 6:50pm
Timo
Darren
The original factory rims were cream outer and brown inner. I have a Series II in the garage that I am keeping "original" as possible but this just looks better without the almost matching rusted wheels.
As for towing it came with the hitch when I got it.
I have used it last year for skiding logs up at our ski club and also have pulled this a couple of times. Its our 18" Foxcub that sits under a tarp at the office and never gets in the water. Sad
T_
Post #144558 11th May 2012 8:33pm
Timo
So after a few years of issues here and there (some sorted by electric ignition) and some just from driving in -20c . Last fall I found that I have blown the head gasket. No too surprised on a 25 year old engine. I first looked at getting it rebuild, then looked at a used V8, then found a nice fella with a few 300TDi and associated tranny and bits to get me going. I sold off some household items then had it loaded into my truck from work with this nice little piece of machinery
Post #328433 5th May 2014 2:23am
Timo
Got the engine home and made a stand to keep it on while I cleaned it up
Post #328434 5th May 2014 2:25am
Timo
Changed the "spigot bushing", pulled it out by filling it with grease and bashing in an old socket to push the bush out
Sorry for the blurry photo
Post #328435 5th May 2014 2:28am
Timo
New clutch
Post #328436 5th May 2014 2:31am
Timo
Had to change the tranny gear shift lever as it was from a disco and needed the quadrant adapter
Pointy bit
Removed
Adapter installed - then re-installed with locktite
Looking good! I did some soda blasting on the tranny and engine but it made a hell of a mess. Works pretty well. next time outside!!!
Post #328437 5th May 2014 2:39am
Timo
Yesterday (Saturday AM) I rolled her into the garage to get ready to start pulling the old engine out
Post #328438 5th May 2014 2:40am
Timo
Seatbox, carpet, mats, tunnel, everything out. It is so much easier to remove things than to install
V8 overdrive anyone...........
Much easier to work on with the hood off
Post #328439 5th May 2014 2:43am
Timo
Rad out
removed all of the fiddly bits
Fuel in and out, choke, throttle, power steering, exhaust manifolds didn't want to come off, had to beat them hard...
Then success
Notice the tranny support aka basketball net.....
Post #328440 5th May 2014 2:47am
Timo
The tranny came out not too bad once I took the frame mounts off
I just lowered it down onto the ground then pulled it out from under the truck. I had to jack the frame up about 1" for it to fit. Good thing I never had it lowered !!!
Seems easy when writing, took about 10 hours of work this weekend....
Some things were really easy then some bolts (propshaft) took 15-20 min to get 1 bolt out. Air tools helped greatly. The only help I had was removing the seatbox. I had my little guy turn the screwdriver when I held the bolts underneath.
I also forgot the remove the speedo cable and had to stop mid tranny removal to unscew that, also missed one breather pipe from tranny to engine.
Initially I thought I could pull the engine and tranny out complete but it wouldn't go. I think if I had removed the tranny mount first it might have happened but it all worked out pretty well.
What a weekend.
I am packed full of family commitments this upcoming weekend but hope to clean things up in the next two weeks and start the install after that.
Tim
Post #328441 5th May 2014 2:52am
